Observer jancools
[Synth 8-27] complex assignment not supported
I have an issue where the assignment I do is not supported:
[Synth 8-27] complex assignment not supported ["R:/Xilinx/Work/Q115/Q115.srcs/sources_1/new/SkewComp.vhd":85]
I'm using oversampling together with GTH transceiver and I put 0's in front of the data to compensate for skew. I made a big variable 1664bit  that can contain the 64 effective data bits with oversamplingfactor max of 26 (64*26 = 1664). In simulation my code works perfectly, but synthesis fails.
I've attached the VHD file. It fails on the line:
TXDATAOVERSAMPLED((i*ofactor + ofactor-1) downto i*ofactor) := (others => '0');
Doing:
upindex := (i*ofactor + ofactor-1);
lowindex :=  i*ofactor
TXDATAOVERSAMPLED(upindex downto lowindex) := (others => '0');
Also does not help.
Is there any smarter way I can do this that synthesizes ?
Thanks in advance
Re: [Synth 8-27] complex assignment not supported
Currently register or array indexing is not supported in the way you have used.You can have the if, else to check the value of the upindex and lowindex and assign a value to the register index.
Example:
If (upindex = 1 and lowindex = 0 ) then
Txdata(1downto o):=0
Achutha
Newbie davidwende
I have a similar problem (Synth 8-27) but am unsure how to rewrite it.
Here are the relevant code sections:
signal A : std_logic_vector(2047 downto 0);
signal address : std_logic_vector(12 downto 0);
signal B : std_logic_vector(39 downto 0);
begin
A( conv_integer(address(6 downto 0) & "11111") downto conv_integer(address(6 downto 0) & "00000") ) <= B(31 downto 0);
David
Historian
Historian
begin
Consider declaring the signals as naturals instead of std_logic_vectors. That makes the conversions go away, plus it makes more sense to the human readers. Oh, yeah, stop using std_logic_arith.
