MrEngineer
[Synth 8-3295] tying undriven pin inst:sl_iport0[35] to constant 0 on virtual IO.
I have included virtual I/O block in block design.
vio_0 - only has output.
vio_1 - has only inputs
vio_2 - has only input.
Both vio_0 and vio2 on out of context synthesis give following warning.
37 x [Synth 8-3295] tying undriven pin inst:sl_iport0[36] to constant 0
I have looked at https://www.xilinx.com/search/support-keyword-search.html#q=Synth%3A8-3295
What does this warning mean? This block is automatically generated.
anusheel
Hi @MrEngineer<,
It means either the pin has no connection or the connected logic was removed by the tool and hence the tool is tying the pin to '0'.
Anusheel
MrEngineer
Thank you for taking time to respond.
I understand what the message says. Here's block diagram. VIO are connected. I am trying to understand why this message.
anusheel
HI @MrEngineer ,
I was able to reproduce the issue by adding VIO in the design:
Finished Final Netlist Cleanup
WARNING: [Synth 8-3295] tying undriven pin inst:sl_iport0[36] to constant 0
WARNING: [Synth 8-3295] tying undriven pin inst:sl_iport0[35] to constant 0
WARNING: [Synth 8-3295] tying undriven pin inst:sl_iport0[34] to constant 0
WARNING: [Synth 8-3295] tying undriven pin inst:sl_iport0[33] to constant 0
WARNING: [Synth 8-3295] tying undriven pin inst:sl_iport0[32] to constant 0
Looks like these messages are coming from the VIO core RTL and can be ignored safely.
Anusheel
