[Synth 8-3332] gone in Vivado 2018.3
I have a scripted build flow which works nicely for a range of projects and a quite wide range of vivado versions, currently the 2017.2 to 2018.3. For 2018.2 and before I often got warnings
   WARNING: [Synth 8-3332] Sequential element (xxx) is unused and will be removed from yyy.
For 2018.3, with an identical build script, I do not see any [Synth 8-3332] messages.
I found the [Synth 8-3332] warnings often useful and thus wonder what happened.
Was that type of warning removed ? If yes, why ?
Or must it be explicitly enabled ?
Thanks in advance for any hint/help,  Walter
Re: [Synth 8-3332] gone in Vivado 2018.3
Hi @wfjmueller,
DId you check that in Vivado 2018.3 those sequential elements are present or not Which were removed in earlier Vivado versions?
If yes, then can you provide a small testcase to check this difference in mulitple Vivado versions at my end?
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
Hi @hemangd,
find attached two projects. Identical sources, one 2017.2 and one 2018.3 project with synthesis step run.
For 2017.2 one gets
   Synth 8-6014
   Synth 8-3331
   Synth 8-3332
For 2018.3 one gets
   Synth 8-6014
   Synth 8-3331
   Constraints 18-5210
--> Synth 8-3332 warnings are gone.
Hi @hemangd,
did somebody have a look at the example cases ? The elements marked as removed in 2017.2 are indeed not used, e.g. because an input is constant. Can easily happen when a module is instanciated but not all functionality is used by the parent. Nevertheless, I always check (via a message filter) what is removed and whether that changes, and this more than once alerted me to little stupid errors. So I'd like to have the 3332 message back.
