jcwill585
Synth 8-439 module not found, even though the same module is instantiated in another module
I'm building an FPGA project with zynq 7000 and I get an error from Vivado Synth 8-439 module not found.   This same module is instantiated in another module.  For a workaround I make a copy of the module code and rename the module.  Then I include the code for the module in the same file.  How can I just use the same name and without copying the code?
anusheel
@jcwill585
Are you using the same name twice to call the same module?
Anusheel
