chris0622
[Synth 8-6426] mix of sync and async problems
I have tried to find a solution on internet. but There is no solution to this kind of problem..
bruce_karaffa
We can't help unless we see the code that lead to these warnings.
chris0622
註解 2020-04-06 221616.png註解 2020-04-06 221637.png註解 2020-04-06 221659.png註解 2020-04-06 221720.png
Thank you!
chris0622
richardhead
What version of vivado is this?
chris0622
2018.1
richardhead
I notice you have the "prmry_clk" for all the CDC blocks is connected to '1' - so logic is likely to be removed with the output locked at a specific value.
Have you tried 2019.2?
