[Synth 8-657] type mismatch for generic 'integer_values' (Mixed language design)
I have a mixed-language design where I would like to instantiate a VHDL module in a Verilog file. The module has the following definition:
entity vhdl_module is
generic (
integer_values: work.vectors_and_arrays.integer_vector(7 downto 0) := (0, 0, 0, 0, 0, 0, 0, 0)
port(
-- list of ports
end vhdl_module;
The vector definition is as simple as follows:
type integer_vector     is array (natural range <>) of integer;
 and my instantiation is:
    vhdl_module
        .integer_values({0,0,0,0,0,0,0,0})
       I_vhdl_module (
//port connections
That does not work and trying something like 32'd0 or 1'd0 instead of just 0 did not work any better. What I want to do is simply passing an integer value so I guess the solution must be rather simple, but I did not find it yet. By the way, the VHDL module works fine in a VHDL design where I instantiate it like that:
integer_values => (0, 0, 0, 0, 0, 0, 0, 0)
So I guess I just need to find the right way to pass an integer value...
Thanks in advance!
javichu
Re: [Synth 8-657] type mismatch for generic 'integer_values' (Mixed language design)
@javichu
Vivado synthesis supports the following VHDL generic types and their Verilog equivalents for mixed language designs: integer, real, string, boolean. -- UG901
The usage looks unsupported. Can you try to modify the generics as normal single integer values and then try to pass it from Verilog module?
Anusheel
@javichu
Can you please check Chapter 9 in below link and make sure the usage is supported:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug901-vivado-synthesis.pdf
Anusheel
Hello @anusheel,
thanks for your reply. I did not find anything about integer values, but either found anything about boolean values and that works fine in my design. In that case I use the following definition:
type boolean_vector     is array (natural range <>) of boolean;
and I can pass my paremeters like that without getting any error:
.boolean_values({1'b0,1'b1,1'b0,1'b0,1'b1,1'b0,1'b0,1'b0})
So I don't know what usages are supported... But let's suppose my VHDL module has just one parameter e.g. a single integer value. How could I pass an integer value from Verilog? would anything like ".integer_value(5)" work? Then I could modify the VHDL module to get my integer values separately. I have also read that System Verilog might work better, but I don't know how to define a file or a code section as System Verilog instead of Verilog. Would that make sense?
Thanks again!
@javichu
Anusheel
