kris_nagar
Synthesis Error
I am trying to synthesize a design in which I have instantiated a component from unisim library. I am getting the following error:
Library unit VPKG is not available in library UNISIM.
Comments won't work. And  vpkg is in unisim. Any idea how to get rid of this error?
Hi Kris_nagar
This may sound strange, but recompile your simulation library.
Bobster
viviany
Can you please post your HDL code here which can be used to reproduce this error?
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
