Synthesis Problem Toplevel Module
Hello folks,
I had a module which reads a text file as an input and do some processing on the content. When I synthesis this module it synthesized fine when I commented the file reading function. However, when I instantiate the same module in my top level module, all the synthesis report is showing is utilization of IO, no LTUs/FFs/BRAMs/DSPs etc. I am not clear on why.
Here is the my top level module:
entity Synth_Test is
    generic(bitWidth: integer:=16);
    Port (
        en: in std_logic;
        clk: in std_logic;
        output1: out STD_LOGIC_VECTOR(bitWidth-1 downto 0)
end Synth_Test;
architecture Behavioral of Synth_Test is
component A is
  Generic(bitWidth: integer:=16; iDim: integer:=40; Dim: integer:=50);
  Port (
            CLK: in STD_LOGIC;
            en: in STD_LOGIC;
            outData1: out STD_LOGIC_VECTOR(bitWidth-1 downto 0)
end component;
begin
DUT: A Generic Map(iDim=>28, bitWidth=>16, Dim=>5)
                Port Map(
                  CLK=>CLK,
                  en=>en,
                  outData1=>output1,
end Behavioral;
Attached is the result of the synthesis result I have for this module. So, why IOs only?
Hi @muleman,
I believe the tool will consider the mapping as a black box with no functionality as such and I only see IO's. Let's see what the community has to comment.
For those who want to try the code
outData1=>output1,
remove the comma from port map to avoid synthesis error.
Prathik
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
Thanks for you reply.
Meanwhile, what are the scenarios that result in IOs only synthesis report?
@muleman
You will need to share the "DUT: A" for us to comment on above results. Above code is only calling the sub-module which looks correct to me.
I would suggest to scan the synthesis log file first in order to understand what tool is doing in the synthesis phase, there must me some warning or info in the synthesis log which can explain this behaviour.
Also, check the generic value passed into the sub-module and validate that tool is passing the correct value from top-module to lower level. You can find these generic values in synthesis log file.
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Here I created two simple modules for an easy debug.
entity B is
  Generic(bitWidth: integer:=8; iDim: integer:=3; Dim: integer:=6);
    Port (
        en: in std_logic;
        clk: in std_logic;
        data1: out STD_LOGIC_VECTOR(bitWidth-1 downto 0);
        data2: out STD_LOGIC_VECTOR(bitWidth-1 downto 0);
        data3: out STD_LOGIC_VECTOR(bitWidth-1 downto 0);
        data4: out STD_LOGIC_VECTOR(bitWidth-1 downto 0);
        data5: out STD_LOGIC
end B;
architecture Behavioral of B is
  component A is
  Port (
            CLK: in STD_LOGIC;
            en: in STD_LOGIC;
            outData1: out STD_LOGIC_VECTOR(bitWidth-1 downto 0);
            outData2: out STD_LOGIC_VECTOR(bitWidth-1 downto 0);
            outData3: out STD_LOGIC_VECTOR(bitWidth-1 downto 0);
            outData4: out STD_LOGIC_VECTOR(bitWidth-1 downto 0);
            outData5: out STD_LOGIC
end component;
begin
DUT: A Generic Map(iDim=>28, bitWidth=>8, Dim=>5)
                Port Map(
                  CLK=>CLK,
                  en=>en,
                  outData1=>data1,
                  outData2=>data2,
                  outData3=>data3,
                  outData4=>data4,
                  outData5=>data5
end Behavioral;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity A is
  Port (
            CLK: in STD_LOGIC;
            en: in STD_LOGIC;
end entity;
architecture Behavioral of A is
	signal count: STD_LOGIC_VECTOR(bitWidth-1 downto 0);
begin
    Dummy: process(clk)
        begin
            if(en='1') then
                if(clk'event and clk='1') then
                    outData1<=(others=>'1');
                    outData2<=(others=>'0');
                    outData3<=(others=>'1');
                    outData4<=(others=>'0');
                    outData5<='1';
		    count<=std_logic_vector(unsigned(count) + 1);
                end if;
            end if;
        end process;
end Behavioral;
B being the top level, this will result in a synthesis report with only IOs.  But if I assign the count value to one of the output ports of B every clock cycle, the synthesis works fine.
outData1<=count;
