Anonymous
Not applicable
Synthesis Rom don't work
Hi there
Why this simple code don't synthesized correctly?
module cmd_rom
#(parameter WIDTH_B=8,MEM_ADDR_B=5)
    input clkin,
  input wire [MEM_ADDR_B-1:0] addr,
    output reg [WIDTH_B-1:0] dout,
    input ren  //read enable
//   (* ROM_STYLE="{AUTO | DISTRIBUTED | BLOCK}" *)
   (* ROM_STYLE = "AUTO" *)
   reg [WIDTH_B-1:0] cmd_rom [(2**MEM_ADDR_B)-1:0];
   initial
      $readmemb("cmd_ram.mif", cmd_rom, (2**MEM_ADDR_B)-1,0);
   always @(posedge clkin)
      if (ren)
         dout <= cmd_rom[addr];
    endmodule
 Why I get:
WARNING:Xst:1781 - Signal <cmd_rom> is used but never assigned. Tied to default value.
Thank you
Ehud
Professor
Professor
Re: Synthesis Rom don't work
I have seen this warning, too.  I believe you can ignore it.  The fact that
it says "tied to default value" rather than "tied to zero" shows that the
ROM is indeed initialized, but XST somehow doesn't see this sort
of initialization the same as  assignment within an always block.
You can look at the resulting logic in the FPGA editor to see if
it worked correctly, or just do a post translate simulation.
Gabor
-- Gabor
Professor
Professor
Gabor
-- Gabor
Historian
Historian
Oh, that's another stupid Xilinx warning that you can ignore.
