tallman18
Synthesis & Implementation Problem
Hi all,
I really dont know where and how to state this problem. I'm working on a project and to test it on hardware I copied the project folder
to another PC which is actually a logic analyzer form TI.  The hardware is tied to this PC so I tested the project on this computer.
After the test and a little change I transfered the project folder back to my own PC. However, the project did not synthesize.
I see that it start to synthesize then pass to implementation phase but do not finish and go back to synthesize phase again and again.
It goes on along time and do not finish. I stop it manually. Here is the "nonsense" part, when I change my PCs date to one day forth
and restart the synthesize it works properly. I know that it is a weird situation, but I do not know what to do...
Any idea, help appriciated..Thanks..
Mahir,
P.S.  my PC:  Windows XP v.2002 Service Pack 3 (Turkish), ISE 9.2.04i j40
        logic analyzer PC:  Windows XP v.2002 Service Pack 3 (English), ISE 9.2.04i j40
Message Edited by tallman18 on 10-01-2009 12:42 AM
matthias.meurer
claenup your project files (in ISE: Project --> Claenup Project Files...) and try again. Maybe this could help.
Matthias
tallman18
I cleaned up project before movıng the project folder, and after error I dıd ıt more tımes but dıd not work.
Thanks...
Mahır
gszakacs
Instructor
Instructor
ISE uses the date of file modification to check whether a process needs to be run again.
It keeps a single date of last completion in the ISE database.  This date is generated from the
clock on the computer where you run synthesis, etc.  The modification date for files is
generated by the host operating system.  For most networks, this means the date is assigned
by the computer which stores the files locally.  So if you have a file that is actually stored
on a remote computer (or "network drive") the file modification date could be newer than the
current time on your computer.  This can happen in a Windows environment if both machines
have the same time and date displayed, but are not set on the same time zone.
When you copied the files back to your computer, the default action for Windows is to leave
the modification date unchanged.  So again any file that was modified on the remote computer
could have a modification date newer than the current date.  One way to get around this if
your files are stored locally is to "touch" (in the Unix sense, i.e. re-write the modification date)
all the source files locally before you start the build.  You can accomplish this manually by
opening each source, making a simple change like adding a space to the end of a line and
then saving it.  If you have MKS toolkit or some other unix-like commands on your computer
you can "touch" the source files that way.
You may want to look at your sources in an explorer window, detail view and check the
modified date.
HTH,
Gabor
-- Gabor
