Synthesis does not correctly interpret timed based constants
In the old ISE tools, I was able to define time based constants and have synthesis interpret them correctly. Vivado does not interpret them and sets them to zero. For example:
constant clock_period : time := 10 ns;
constant cycle_period : time := 100 us;
constant clocks_per_cycle : integer := cycle_period/clock_period;
Is there a particular library needed by Vivado to properly interpret time based constants?
Mentor
Mentor
This is a known issue with Vivado synthesis.  It usually makes an error when doing division on type TIME.    The workaround is to use type REAL, which is IEEE double precision.   This may require more documentation in the comments to make the units and scale more obvious, but the arithmetic is always correct.
Mentor
Mentor
Thanks!
