Visitor nznkn
Synthesis failed with EXCEPTION_ACCESS_VIOLATION
Hello.
Vivado fails during synthesis for the attached project (which contains possibly errneous HDL source).
Syhthesis log ends with:
INFO: [Synth 8-4471] merging register 'q_b_wire_reg[31:0]' into 'q_a_wire_reg[31:0]' [C:/Users/yamada/Desktop/project_1/project_1.srcs/sources_1/new/main.v:13188]
Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
Please check 'C:/Users/yamada/Desktop/project_1/project_1.runs/synth_1/hs_err_pid11140.log' for details
hs_err_pid11140.log:
# An unexpected error has occurred (EXCEPTION_ACCESS_VIOLATION)
Stack:
no stack trace available, please use hs_err_<pid>.dmp instead.
I'm using Xilinx Design Tools Vivado HL Design Edition 2018.2 (reproducible with 2018.1 too) on Windows 10.
Thank you.
Re: Synthesis failed with EXCEPTION_ACCESS_VIOLATION
I can reproduce the issue with your code.
This is a tool issue. I will file a CR.
If you change the code like below to put q_a_wire and q_b_wire into different always blocks, the crash issue will not occur.
module ram_dual_port
clk,
clken,
address_a,
address_b,
wren_a,
wren_b,
data_a,
data_b,
byteena_a,
byteena_b,
q_a,
q_b
input clk;
input clken;
input [(1-1):0] address_a;
input [(1-1):0] address_b;
output wire [31:0] q_a;
output wire [31:0] q_b;
reg [31:0] q_a_wire;
reg [31:0] q_b_wire;
input wren_a;
input wren_b;
input [31:0] data_a;
input [31:0] data_b;
input [1-1:0] byteena_a;
input [1-1:0] byteena_b;
reg [32-1:0] ram[1-1:0];
always @ (posedge clk)
if (clken)
begin
if (wren_a)
begin
if (byteena_a[0]) ram[address_a][0 +: 32] <= data_a[0 +: 32];
q_a_wire <= {32{1'bX}};
end
else
q_a_wire <= ram[address_a];
end
if (clken)
begin
if (wren_b)
begin
if (byteena_b[0]) ram[address_b][0 +: 32] <= data_b[0 +: 32];
q_b_wire <= {32{1'bX}};
end
else
q_b_wire <= ram[address_b];
end
assign q_a = (clken) ? q_a_wire : 0;
assign q_b = (clken) ? q_b_wire : 0;
endmodule
But you'll receive another error:
Error:[Synth 8-2913] Unsupported Dual Port Block-RAM template for ram_reg.
For the correct Dual Port BRAM inference template, please refer to UG901.
-vivian
@nznkn
A quick question, what happens when you disable the register merging(-keep_equivalent_registers)?
Anusheel
Anusheel
Visitor nznkn
Nothing happened - synthesis still fails with the access violation.
Visitor nznkn
I got smaller reproduction code:
	clk,
	clken,
	address_a,
	address_b,
	wren_a,
	wren_b,
	data_a,
	data_b,
	byteena_a,
	byteena_b,
	q_a,
	q_b
input  clk;
input  clken;
input  wren_a;
input  wren_b;
    if (clken)
    begin
        if (wren_a)
        begin
        end
        else
        if (wren_b)
        begin
        end
        else
    end
endmodule
module top(clk);
input clk;
reg  x_address_a;
reg  x_write_enable_a;
wire [31:0] x_in_a;
wire [31:0] x_out_a;
wire  x_address_b;
wire  x_write_enable_b;
wire [31:0] x_in_b;
wire [31:0] x_out_b;
ram_dual_port x (
	.clk( clk ),
	.clken( 1'b1 ),
	.address_a( x_address_a ),
	.address_b( x_address_b ),
	.wren_a( x_write_enable_a ),
	.wren_b( x_write_enable_b ),
	.data_a( x_in_a ),
	.data_b( x_in_b ),
	.byteena_a( 1'b1 ),
	.byteena_b( 1'b1 ),
	.q_a( x_out_a ),
	.q_b( x_out_b)
endmodule
Silly question - how long has your computer been running?
If it's been more than 3 or 4 days since I rebooted my computer (Windows 7) I get nearly identical error as you.  Rebooting fixes it for a few more days.
ken
clk,
clken,
address_a,
address_b,
wren_a,
wren_b,
data_a,
data_b,
byteena_a,
byteena_b,
q_a,
q_b
input clk;
input clken;
input wren_a;
input wren_b;
if (clken)
begin
if (wren_a)
begin
end
else
end
if (clken)
begin
if (wren_b)
begin
end
else
end
endmodule
-vivian
