Synthesis failure
I am trying to implement ring oscillator design. Circuit is attached to mail.
I have used structural type of coding.
After synthesis I found that AND gate is not synthesized while behavioral simulation works correctly but PNR simulation does not work as AND gate is not synthesized. How this can be done?
Re: Synthesis failure
@vinayak_sasken123 can you show the actual code which you used? this looks simple enough and it's already patented.
I have attached the code
