Visitor faizan.sayed
Synthesis issue : Signed Comparison synthesis issue (Ultrascale + Vivado 2018.x + Poven code on ASIC and earlier FPGA)
Hi Xilinx Team,
I would like to report a synthesis issue which took us days to figure out in complete design.
Figure below shows the code snippet where it failed to synthesize correctly(what we expected) in xilinx vivado 2018.x version.
Note: Code is Legacy code proven on ASIC and Xilinx Virtex 6 FPGA with synopsis synplify pro synthesis.
Finally we had to update the code for compatibility with Vivado with following changes:
Faizan Sayed
Re: Synthesis issue : Signed Comparison synthesis issue (Ultrascale + Vivado 2018.x + Poven code on ASIC and earlier FPGA)
Hi @faizan.sayed
Is it possible for you to share the design to debug this issue further?
Manusha
Hi Manusha,
This particular Problem got solved as stated in the ticket image number 2.we had to change the RTL to make it compatible with Vivado and synplify pro.
we are facing now another issue of same kind,which we are not able to solve with above changes. still we are looking for solution .
i can share only code snippet, where we are having issue and design checkpoint file remotely.
Faizan Sayed
Scholar richardhead
Without a full code example showing the problem its difficult to understand really what the problem is.
Your code shows no declarations or packages used.
You do not state what "synthesised correctly" means.
