hwlee
Synthesis of real type values is not supported
Hi, when I try to synthesize the XADC.v code from Xilinx in ISE 14.5, it shows the error message.
"ERROR:HDLCompiler:812 - Line 215: Synthesis of real type values is not supported."
Any idea to solve this? or just replace the 'real' data type?
Thanks in advance.
kdeshwal
Hi @hwlee ,
Real data type is not synthesizable data type in Vivado.
Refer link for details - https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug901-vivado-synthesis.pdf#page=236
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
richardhead
Simply replace the real data type. Use reg instead.
drjohnsmith
I don't know this XADC.V code you refer to.
   is it supplied by Xilinx ?
BTW: Why 14.5 ?
   What OS you running on ?
kdeshwal
Hi @hwlee ,
Kuldeep
kdeshwal
Hi @hwlee ,
Please let us know if the query is resolved or you have any follow-up query.
Kuldeep
hwlee
Hi, yes. The XADC.v code is supplied by Xilinx.
hwlee
Thank you.
The problem has solved by not synthesize the XADC.v code. Instead, copy over the XADC instantiation template from language template panel, and paste in inside the ADC top level module code (which you create yourself) with all ports declared which corresponding to the ports available from XADC instantiation template.
hwlee
Thank you, the problem has solved.
drjohnsmith
@kdeshwal
