Synthesis of the IFF event qualifier
Hi there,
Can someone please shed some light on the difference between the two code structures below?  I am puzzled.
always @ (posedge clk iff datavalid) begin
end
This worked perfect in simulation, but not in real life, nor was the integerated logic analizer (ILA) showing anything promising. Actually ILA was showing total nonsense.
(I was actually trying to save power with the iff event qualifier, hoping it would use the CE (clock enable) inputs of the FFs.)
Then I changed it to the code below and now it works:
always @ (posedge clk) begin
if (datavalid) begin
end     //  for if
end    // for always
What is it about the iff  that I should know better?
Hi @mbence76,
I have filed a CR (Change Request) with the development on this issue. If this construct is not supported (as per UG 901) then tool should throw a message. They may make necessary changes in upcoming Vivado versions.
hemangd
Hi @mbence76,
From my thinking, IFF is not a supported synthesizable construct in Vivado Synthesis.
Raj.
Hi Raj,
yes, you must be right, but the real question is now:
how come that my Vivado synthesizer did synthesize, did implement, dit generate a bitstream file (when the RTL source file was using IFF) ?
There was no "unsupported IFF construct" message or "synthesis failed" message. :-(
Have a nice day!
Miklos
Hi @mbence76,
>>This worked perfect in simulation, but not in real life.
What do you mean by this ? Please elaborate.
And share the synthesis log file to evaluate when you were using IFF event qualifier.
hemangd
Hi hemangd,
The FPGA panel received bytes thru SPI from an MCU panel and sent back bytes to the MCU thru the same SPI. A Putty terminal window showed that the bytes from the FPGA were nonsense  (when the FPGA image was created from an RTL source containing IFF). Simulation revealed no difference in behavior between the IFF and the  if(datavalid) begin...end   structure.
I have re-written the code since then way too many times, but created a brand new one-file project to recreate the phenomena. Here it is, please try it in Vivado 2018.2, under Win10.  It compiles without an error, without a warning.
`timescale 1ns / 1ps
module topmodule_t(
    input        clk,
    input        i_data,
    output logic o_data
logic[2:0] cnt = 0;
logic       dv = 0;
    if (cnt==0) dv <= 1;
    else        dv <= 0;
    cnt <= cnt + 1;
end
always @ (posedge clk iff dv) begin
    o_data <= i_data;
end
endmodule
Im going to be awkward here, and point out the simple answer is that "IFF" is not listed as a supported SV feature in the synthesis user guide (UG901):
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug901-vivado-synthesis.pdf
Secoondly, the main difference is that using iff really implies clock gating, rather than a clock enable, and so would never be supported in an FPGA as clock gating is definitely not recommended.
Here is post from stack exchange baically asking the same as you:
https://electronics.stackexchange.com/questions/177069/is-event-control-iff-in-systemverilog-the-same-like-clock-gating
TL:DR: Its a clock gating construct - dont use it unless you really want a gated clock.
Yes, thank you, I have given up using IFF. However the other question, as to why the synthesizer does not report IFF as an "unsupported feature", still puzzles me. Please see my previous post. Miklos
Hi @mbence76,
hemangd
Hi @mbence76,
As per the discussion with the developement, Vivado 2018.3 supports IFF event qualifier and hence synthesized design shows clock gating with AND gate (LUT).
Hence, UG 901 will be updated according to it.
hemangd
Wow, that is good news. I am not sure about the delay of the clock gating AND gate (LUT), but I am sure Xilinx knows what they are doing. :)
