Synthesis taking too long time -Vivado 2014.4 System Edition
Hi guys,
I am trying to generate the bitstream from the Project given in document (xapp1234-kcu105-axi-quad-spi), specially for the Project folder enhance quad mode. In fact i have downloaded it from the given link in that Manual and created the Project using Vivado 2014.1. In my case synthesis takes more than 1 day and still ist is not ending. Anybody is having any previous experience with this.?
Thank you.
@mgdudhat
Thank you for your reply.
If you do not have further questions on it then feel free to close this thread by marking it as accepted solution so the community remains healthy.
hemangd
How much memory (RAM) does your computer have?  The biggest factor, in my experience is how much RAM you have.  How many CPU cores?  A multi-core computer can perform several synthesis tasks in parallel, although it won't help much with place & route.  Can you try a newer version of Vivado?
Thanks. Actually my Laptop having 8GB RAM and ist Intel Core (i3), 2,30GHz. Actually given Project is with this Vivado 2014.4 System Version as per document, so i tried it with that only. In order to avoid any update stuff with IPs, I synthesized this Project with this Version only.
The peak memory that Vivado uses for that device is given in https://www.xilinx.com/products/design-tools/vivado/memory.html as 7GB.  Is your system swapping memory to disk a lot while building the FPGA?  Have you tried closing all other applications while you build?  Once the computer starts to swap physical memory (RAM) for virtual memory (disk) the build times are much longer.
@mgdudhat
It looks like a machine specific issue. Which OS version are you using with this Vivado?
hemangd
Hey thanks. all Right. i am using windows 10 Home OS.
@mgdudhat
Windows 10 is an unsupported OS for Vivado 2014.4.
Kindly use supported OS for it as below.
hemangd
@mgdudhat
Would you like to provide an update on this issue?
hemangd
hi, i guess that was the Problem (os issue) that you provided. thank you.
@mgdudhat
hemangd
