gochango
Synthesizable Assertion
I was reading "Generating Hardware Assertion Checkers" and it mentioned that Xilinx was able to covert Synthesizable Assertions into a checker. Is this still possible? How is this done?
kdeshwal
Hi @gochango ,
If you are concerned about VHDL assertion support, then yes these are supported and you need to enable them by running a tcl command.
Refer AR#65415 for details.
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
bitjockey
Of course be warned that as of 2018.1 it is STILL buggy as all get-out.
process(Clk)
if Clk'rising_edge then
    //some conditional state case
    if (not Rdy) then
        Report "Warning, bus error" Severity Warning;
        // actual bus error logic here
You would EXPECT this to only evaluate at run time in simulation and get IGNORED by compile time synthesis.  However no. It unconditionally evaluates the Report keyword and actually puts a Warning in your log file.
You have to do BS work-arrounds like "Assert false Report ..." because even though a 'naked' Report is a sub-case of an Assert statement, the compiler treats them 100% differently and stupidly.
richardhead
@bitjockey that bug is fixed in 2019.1. Runtime assertions are ignored from synthesis,  and only static elaboration ones are checked.
