Visitor lowuze
Synthesize errors associated with mpmc ISE 14.7 Virtex 6
Hello!
I design my project in EDK and use mpmc core.
The following errors occur during the synthesis:
ERROR:Xst:528 - Multi-source in Unit <v6_ddrx_rddata_sync> on signal <n0122<71>>; this signal is connected to multiple drivers.
Drivers are:
   Output port RAM64X1D:DPO of instance <mpmc_0/mpmc_core_0/gen_v6_ddr3_phy.mpmc_phy_if_0/u_phy_read/u_phy_rddata_sync/gen_c0.u_rddata_sync_c0/gen_ram[71].u_RAM64X1D>
   Output port RAM64X1D:DPO of instance <mpmc_0/mpmc_core_0/gen_v6_ddr3_phy.mpmc_phy_if_0/u_phy_read/u_phy_rddata_sync/gen_c0.u_rddata_sync_c0/gen_ram[67].u_RAM64X1D>
ERROR:Xst:528 - Multi-source in Unit <v6_ddrx_rddata_sync> on signal <n0122<70>>; this signal is connected to multiple drivers.
Drivers are:
   Output port RAM64X1D:DPO of instance <mpmc_0/mpmc_core_0/gen_v6_ddr3_phy.mpmc_phy_if_0/u_phy_read/u_phy_rddata_sync/gen_c0.u_rddata_sync_c0/gen_ram[70].u_RAM64X1D>
   Output port RAM64X1D:DPO of instance <mpmc_0/mpmc_core_0/gen_v6_ddr3_phy.mpmc_phy_if_0/u_phy_read/u_phy_rddata_sync/gen_c0.u_rddata_sync_c0/gen_ram[66].u_RAM64X1D>
These modules are part of the mpmc, and I have no way to fix anything here.
Re: Synthesize errors associated with mpmc ISE 14.7 Virtex 6
@lowuze
One way to filter out whether this is RTL issue or issue with the IP, run the example design of IP(.xco) with same IP configuration.
If you see the error in IP example design as well, please post a new query in IP board. And if there are no errors, try to scan the RTL and look for the signals and its connections which are mentioned in error generated by XST.
Anusheel
Scholar dpaul24
@lowuze,
Can you show us the RTL where a signal is driven from multiple sources?
FPGA enthusiast!
All PMs will be ignored
Visitor lowuze
How do I get the RTL without making a synthesis?
Scholar richardhead
@lowuze
RTL is the source code.
Multiple drivers occur if you have several signals driving the same net.
Hi @lowuze,
You can check the connections in RTL schematic (elaborated design) which are showing as multiple drivers in error messages.
And then make changes as per your requirement in the source files.
hemangd
hemangd
Visitor lowuze
Ok, then another question. How do i get the RTL schematic without synthesis in ISE? When i click on "View RTL Schematic" the synthesis begins and and XST gives those errors. And where can I find the source files of mpmc?
@lowuze
Opening RTL schematic without running synthesis is not possible in ISE. This feature is present in Vivado.
You can run "Check Syntax" which will not run synthesis.
--Syed
@lowuze
Anusheel
Visitor lowuze
The problem was not solved. It was decided to do the project on the axi bus
