Synthesize time is reduced in 2018.3 vs 2018.2
It seems the time may be better between 9-19% faster to synthesize.
The default power value value is slightly lower for synthesis, but seems to be under the true value needed when implemented (whereas before, it seemed to be the same)
Note: Measure on one project… your mileage may vary
I am curious if others are seeing similar improvements.
Re: Synthesize time is reduced in 2018.3 vs 2018.2
@xilinxacct
Good to hear that 2018.3 synthesis has better runtime as compare to 2018.2.
You can also reach out to power experts in below board where power related queries are handled:
https://forums.xilinx.com/t5/Design-Tools-Others/bd-p/OTHER
Anusheel
