TclStackFree: incorrect freePtr. Call out of sequence?
I have encountered this error during the synthesis:
"TclStackFree: incorrect freePtr. Call out of sequence?"
I am using Vivado 2013.3 on Linux system.
I have already tried some solutions I have found in this forum:
http://forums.xilinx.com/t5/Synthesis/Unknown-Vivado-Synth-Error/td-p/387265/highlight/true
which the user downgraded the version of Vivado from 2013.3 to 2013.2, and
http://www.xilinx.com/support/answers/55687.htm
which suggests to type a specific tcl command before starting the synthesis.
The second solution didn't work and, instead downgrading my version to 2013.2, i have upgraded to 2013.4, but the error persists.
I have to add that Vivado is trying to synthesize a system that will allocate much more than the available resource of Virtex 7. I have 5 different configurations of my system, all of them based on a different size of the problem. The first 4 configurations worked well with the synthesis, everytime allocating ten times the resources the previous configuration allocated.
The 4th one, allocated 31% of slices for logic and 51% of slices for memory. Since the size of the 5th will require at least 10 times the resources used on the 4th configuration, i am sure the error depends for this reason, but, since the synthesis phase does not expect any placing, i expect the synthesis performs smoothly.
I have attached the log file with the part of the RTL verification erased.
What do you think?
Re: TclStackFree: incorrect freePtr. Call out of sequence?
Can you try using "Flow Run time optimized" synthesis strategy?
Try setting "Flatten_hierarchy" to NONE in synthesis settings and see if that helps.
Deepika.
Deepika.
Hi Vemulad, thanks for your reply.
At the moment the error is still there, even applying your solution.
Antonio
Hi Antonio,
Did you try both the suggestions and still seeing the issue?
Is is possible to share the test case for debug?
Deepika.
Deepika.
At the moment my only test case is my general testbench which let my developed system entirely work
Antonio
At the moment i am using Vivado 2013.2 to try to synthesize, as suggested in the first link i shared. It doesn't seem to stop as soon as with 2013.3 and 2013.4. It is still working!
But i think it is too early to say it's completely working. Since the 4th configuration took around 1h to be synthesized, this will take many hours. Hopefully, i hope i can tell you more tomorrow
Antonio
Too many hopes, sorry.
The synthesis with 2013.2, after few hours, terminated with the same error, but adding also the phrase
"3 unexpected non-zero reference counts".
Antonio
1. Did you try setting "flatten_hierarchy" to NONE in 2013.2 or 2013.4?
2. Did you try using synthesis strategy "Run time optimized" in 2013.2 or 2013.4?
Deepika.
Deepika.
I have tried to you use the strategy "Run time optimized" and i saw that the script using this strategy already sets flatten_hierarchy to NONE. Still does not work with all the versions.
Antonio
Can you please share the testcase so that we can debug this at our end??
Thanks,Vijay
Did you solve the problem?I met the same problem。
 I am using Vivado 2014.3 with Window 7-64bit
I've faced same problem. Win7 x64, Vivado 2014.3 and 2014.4. Simplest project consists of one register. Flow_RuntimeOptimized strategy don't help.
After some tests, I've solved my problem. Error was caused by cyrillic letters in computer name.
Maybe it will help someone.
 It works, thank you very much!
@g.pavlikh
Thanks for posting your findings.
Is the issue with the computer name or the path name?
Can you give us the snippet so that we can try reproducing it and see it is fixed?
Achutha
Problem was with the computer name, it was "User-ПК". After changing name to "User-PC" error has disappeared. Path to files is in english only.
2015.1 still have this issue.
Just got this error too with Vivado 2016.3. I was able to use Vivado 2015.3 with no problem.
2016.3 only started working when I moved it to a different folder. Perhaps the path was too long? Using Windows 7/64.
Advisor
Advisor
I am getting this same error message on a Kintex Ultrascale 040 design under Vivado 2016.4.
I applied the recommendation from AR# 55687 and that seems to fix the problem for now.
DSP in hardware and software
@pedro_uno
This could be a different issue. Can you please share more details and log files for us to understand the root cause?
In such cases, we might need to look into the design in order to provide a suitable work around.
Anusheel
Helpful answer -> Give Kudos
Advisor
Advisor
Anusheel,
I have lost the exact configuration that gave me this error message.  If I see it again I will try to capture it for you.
  Pete
I am also facing similar problem on Vivado 2017.3.1.
I am using generate statement in my Verilog code.  The tool was able to synthesize up to for loop limit 15, when it exceeds the 15 it's throwing an error (TclStackFree: incorrect freePtr. Call out of sequence?).
I have tried your suggestions but still, it's not working.
What would be the problem?
Hi @anusheel and all,
I got the same issue on Vivado 2016.2. Attached is the log file.
If you need more detail info, please let me know!
Kind regards,
Khoa
Hi @khoa_pham,
Create a fresh new thread with your issue to get it noted by the community.
hemangd
hemangd
