Visitor 463717263
The logic for <sram_sel> does not match a known FF or Latch template.
hi
would you tell me what's wrong in my project.
always @(negedge clk or negedge rst)
begin
begin
if (!rst)
sram_sel <= 0;
end
begin
if (we0 == 0 && addr0_wr == 19'd512)
begin
sram_sel <= ~sram_sel;
end
if (we1 == 0 && addr1_wr == 19'd512)
begin
end
end
end
cheers
micheal
Teacher eteam00
Re: The logic for <sram_sel> does not match a known FF or Latch template.
Try this.
begin
    if (!rst)    sram_sel <= 0;
    else  // <-- missing from original code
        begin
            if (we0 == 0 && addr0_wr == 19'd512)    sram_sel <= ~sram_sel;
            if (we1 == 0 && addr1_wr == 19'd512)    sram_sel <= ~sram_sel;
        end
end
If you are selecting a register or sram based on a we pulse, your logic is in error.  A more typical decoding of we and address inputs is:
begin
    else              sram_sel <= ( (we0 == 0) || (we1 == 0) ) && ( addr0_wr == 19'd512 );
end
-- Bob Elkind
SIGNATURE:
Summary:
In you always block,reset if level triggered & clock is edge triggered signal. Mixing of both is is not recommended.
Hi Micheal,
Try the below code, it works
begin
if (!rst)
begin
sram_sel <= 0;
end
else if (we0 == 0 && addr0_wr == 19'd512)
begin
end
else if (we1 == 0 && addr1_wr == 19'd512)
begin
end
end
Deepika.
Deepika.
Scholar pratham
Every time you were closing the if statement without the else if or else statement So obvoulsy this template was not matching with the known flip flop or latch template.
Add else if and put the conditions of your codes,
-Pratham
Teacher eteam00
This is incorrect.  The edge sensitivity for both clock and async reset is the proper syntax.
-- Bob Elkind
SIGNATURE:
Summary:
Teacher eteam00
Try this.
begin
        begin
        end
end
begin
end
-- Bob Elkind
SIGNATURE:
Summary:
Visitor 463717263
Visitor 463717263
Thank you very much~deepika~
Visitor 463717263
Thank you very much~pretham~
Visitor 463717263
Thank you very much Bob~
Visitor 463717263
Thank you very much~ The problem has been solved~
