alexis_jp
Timing analysis: use case?
To avoid wasting time waiting for the end of the implementation to have an idea of which paths might fail, I try to run the Timing summary after the synthesis.
All the xilinx IP cores we use in our design have timings inside the core with way too many failing endpoints.
Example with the DDR4 MIG:
Same for the MMCM, PCIe Hard IP core, GTYs,
  • What's the point of using the Synthesis' timing analysis if it provides completely wrong data?
  • What's the use case in which this can be useful for someone?
  • Any explanation regarding these results?
  • Is something wrong in my project/Xilinx cores?
viviany
As the design hasn't been placed or routed, the net delays in the post-synthesis timing report is estimated based on the logic connections and fanout.
As a result the timing result is not accurate. Paths that are flagged as "fail" post-Synthesis would be fixed after routing.
In general, you can focus on the paths with slack larger than 300ps (e.g. -0.4xx ns), especially for very large negative slack.
Those paths may have significant problems like high logic level, high fanout, suboptimal clock topology, or incorrect CDC constraints.
Fixing those problems in the early stage of the design flow would save time and reduce design iterations.
Hope this helps.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
viviany
Hope this helps.
-vivian
alexis_jp
Thank you @viviany.
I would have expected to see that in ug901.
I understand I should care on timing >300ps only and ignore everything else.
