True Dual Port Asymmetric RAM Write First (Verilog)
As I was reading the UG901, I noticed that on page 138 in the True Dual Port Asymmetric RAM Write First (Verilog) section, the code was written as
always @(posedge clkB)
begin
if (enaB) begin
if (weB)
RAM[addrB] = diB;
readB = RAM[addrB] ;
end
end
assign doutb = readB
To my understanding, the blocking assignment here is used for the write-first mode. My question is very simple, why using the top method instead of the bottom one? Is there a specific reason for that?
I guess the top method will introduce a small delay between diB and doutb, is that right?
begin
if (enaB) begin
if (weB)
RAM[addrB] <= diB;
doutb <= diB ;
end
end
@mengjiuxi,
Simulate and synthesize both models. You will get your answer. :-)
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
