Unconnected net in RTL schematic
Hi, I often have a problem with the RTL schematics of mealy FSMs, such as the simple one described in the following example:
process(clk)
begin
	if rising_edge(clk) then
		case state is
			when idle =>
				counter <= counter + 1;
				if counter = 2 then
					state <= read_val;
				end if;
			when read_val =>
				if counter = 15 then
					state <= next_val;
					counter <= 0;
				end if;
			when next_val =>
				state <= idle;
		end case;
	end if;
end process;
process(state)
begin
	case state is
		when read_val =>
			buff_wr <= '1';
		when others =>
			buff_wr <= '0';
	end case;
end process;
In short, I have tree states with state transitions determined by a counter, and "buff_wr" signal used to enable a FIFO. In this example buff_wr should be '1' only during the read_val state.
In the resulting RTL schematic the buff_wr signal, while properly generated, is not connected to the fifo (event_ff), which have its wr_en signal tied to ground.
RTL SchematicRTL Schematic
I don't get any errors or warnings during synthesis and the synthesis schematics looks correct:
Synth schematicSynth schematic
Looking around I found some posts reporting a similar behaviour in the older ISE toolchain (apparently caused by a bug), but I was not able to find any similar reports for vivado (I'm using the 2018.2 version). So I was wondering If there was something wrong with my codestyle, since I often see similar issues with signals generated by asychronous processes.
I should also add that the RTL schematic is generated properly if I remove the last state (next_val) and skip directly to idle.
Thank you for any help you can provide.
well, I updated to vivado 2019.1 this morning (coming from 2018.2) and I no longer have this issue. I'm guessing it was more some kind of bug of the RTL viewer than something wrong with the code.
Hi @john ,
Can you provide the full testcase and elaboration of your question in details to investigate this issue?
I can see that buff_wr mux output is trimmed. But need to investigate it further.
hemangd
Hi, not sure what you mean by full elaboration, I am attaching a simple testcase that fully reproduces the issue on my system.
Hi @john ,
I am addressing the main issue here which you are talking about that buff_wr output is unconnected and needs to be connected to wr_en in elaborated design.
I have modified your RTL and made a single sequentlal block for FSM which resolves your above mentioned query. Code is attached here. Try it at your end.
hemangd
Thank you for your answer. I know I can fix this problem by using a synchronous design, my doubt is why I get that result with an asynchronous process, especially since it seems that I get the correct result after synthesis.
Hi @john ,
Are you able to see buff_wr in synthesized design? Is your functionality correct in post synthesis simulation?
Because, It is visible with synchronous design, single synchronous block as shown below.
hemangd
yes, as also shown in the second picture in the first post I can see the signal in the synthesized design. It also behaves properly in the post synth simlation. It's not connected only in the RTL schematic.
Please accept your own answer as solution to close this thread.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
