Unsupported Clock Statement error
I'm making a divide by 5 clk like this:
if (rising_edge(clk) or falling_edge(clk)) then
    count:= count+1;
     if count=4 then
     sma_clk<= NOT sma_clk;
     count:=0;
     end if;
   end if;
it passes syntax check but the synthesis gives me ": unsupported Clock statement. error.
ritchiew@golighthouse.com
Welcome to the Xilinx Forum !
Your VHDL code snippet give us lots to talk about…
1) As steven notes, the Xilinx tools will complain about your “if (rising_edge(clk) or falling_edge(clk)) then”.  In a VHDL process, you can use either “rising_edge(clk)” or “falling_edge(clk))” but not both (see VHDL Sequential Logic in Xilinx document UG901).
2) You call “sma_clk” a clock, but your VHDL indicates that it is a signal (officially called a toggle).  Toggles are very useful, but they should not be used directly as clocks.  For example, you should not elsewhere use “if (rising_edge(sma_clk)) then”.
3) If you want “sma_clk” to be a clock then you should generate it using a FPGA Clock Management Tile (CMT), which is probably how you are generating “clk”.   That is, we usually bring a single base clock into the FPGA and immediately route it to a CMT, which can then be configured to create other clocks (typically up to 6ea) needed by the design.  For many of the Xilinx FPGAs, configuring a CMT is described by document PG065).
4) If you want “sma_clk” to be a toggle, then we usually create the toggle, sma_tog, as shown in process, P1, and use the toggle as shown in process, P2:
P1: process(clk)
    constant COUNT_MAX : integer := 4;
    variable count : integer range 0 to COUNT_MAX := 0;
    begin
        if rising_edge(clk) then
            if(count = COUNT_MAX) then
                sma_tog <= '1';
                count := 0;
            else
                sma_tog <= '0';
                count := count + 1;
            end if;
        end if;
    end process P1;
P2: process(clk)
    begin
            --here, things done at rate of clk
            if(sma_tog = '1') then
                --here, things done at rate of sma_tog
            end if;
        end if;
    end process P2;
Cheers,
Mark
Does your target support dual-edge flip-flops? Also, similar to tri-state buffers, dual-edge flip-flops oftentimes need to be in the top level module / entity.
AH! Thanks for the hint. I'll check that out. Thanks
P1: process(clk)
    begin
                sma_tog <= '1';
                count := 0;
            else
                sma_tog <= '0';
                count := count + 1;
            end if;
        end if;
    end process P1;
P2: process(clk)
    begin
            end if;
        end if;
    end process P2;
Cheers,
Mark
Thank you so much for your explaination. I'm new to the VHDL world, so this will be a big help to me, thanks!
Ritchie
Just as a follow up, I used the Spartan 3E DCM primative and setting up a divide by 5 clock was easy as pie. The clock was connected to an external sma connector and used to drive an A/D converter demo board.
ritchiew@golighthouse.com Could you help to mark solution with the answer that helped you solve the issue?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
