asai9493
Use " array" in VHDL
I have a problem with an initialisation of an array.
**Simualtion**
- main process
architecture Behavioral of fir is
type h_array is array (integer range 0 to 31) of std_logic_vector (9 downto 0);
signal coeff_int : h_array := (others => (others => '0'));
if rising_edge(MainClk) then
coeff_int <= coeff_int(conv_integer(coeff_input))((bits - 1) downto 0); -- error line
--> write a h_array to coeff_input_address in the h_array
if coeff_write = '1' then
coeff_int (conv_integer(coeff_input_address)) <= coeff_input;
end if;
***Error:*** Indexed name is not a h_array
Can anyone help me to fix this error?
My corrections in the File:
 - I have fixed an error in the beginning ( "port description"
coeff_write: in std_logic;
dpaul24
@asai9493 ,
try to use to_integer() instead of conv_integer()
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
richardhead
Please post the whole code and the actual error.
It appears you are trying to assign a slice from a single std_logic_vector back to the entire array. Maybe you have a typo? We cant see without the real code?
asai9493
@richardhead I have added
richardhead
@asai9493
The problem as as I specified before - this line:
coeff_int <=   coeff_int(to_integer(signed(coeff_input)))((bits - 1) downto 0);  -- signed(coeff_input)
coeff_int is an array, and oeff_int(to_integer(signed(coeff_input)))((bits - 1) downto 0) is a single std_logic_vector
You cannot assigned a single std_logic_vector to a signal of type h_array. This would be clear from the error.
asai9493
@richardhead
originally I used
This code was given as example.
coeff_int should be used later to take a product (" multiplier"). I was thinking to define a new variable as
coeff_int_new <= coeff_int(conv_integer(coeff_input))((bits - 1) downto 0);
Then it should be defined and it is not what I want
varunra
Try indexing the array. coeff_int(<variable>)
