Use some equivalent for $display in vhdl
Greetings ... someone can help me find an equivalent, or some way to perform this operation in vhdl.
$display( "//! g1_wbus_stack.v: ADDR = 0x%08x, WDATA=0x%08x" , o_wbus_addr,o_wbus_data);
Any help is welcome, thanks in advance.
Re: Use some equivalent for $display in vhdl
This doesn't get you there entirely, but you can use the 'IMAGE attribute to print the integer representation of the value. For example:
assert false report "g1_wbus_stack.v: ADDR = " & INTEGER'IMAGE(o_wbus_addr) & ",WDATA= " & integer'Image(o_wbus_data) severity note;
where I'm expecting o_wbus_addr to be integer type. If it isn't you'll have to do a type conversion.
Here's the same thing less verbosely:
report "g1_wbus_stack.v: ADDR = " & INTEGER'IMAGE(o_wbus_addr) & ",WDATA= " & integer'Image(o_wbus_data);
This probably wouldn't work though, as the signals (?) are probably std_logic_vector, so the code might need to be:
report "g1_wbus_stack.v: ADDR = " & INTEGER'IMAGE(to_integer(unsigned(o_wbus_addr))) & ",WDATA= " & integer'Image(to_integer(unsigned(o_wbus_data)));
Well, that's rather ugly.  This is why most VHDL users I know implement their own package of "to_string" and "to_hex_string" functions that are overloaded to support all types that need printing.  Unfortunately, such packages aren't standardised (or if they are, they aren't supported by the tools).
AFAIK, VHDL is incapable (by design!) of implementing "varargs" - a function with a variable number of parameters of different type (even though it does support optional parameters and default values).  This means that it won't ever be able to do printf-like formatting.
Scholar richardhead
@allanherriman
VHDL has standardised to_string - VHDL 2008 has a to_string function for all standard types. In addition, all bit-based types (std_logic_vector, (un)signed, bit_vector) have to_hstring and to_ostring functions also. Even better, these are now part of their respective libraries, so the non-standard std_logic_textio is redundant.
So VHDL 2008 allows (with no special libraries or custom packages)
report "g1_wbus_stack.v: ADDR = 0x" & to_hstring(o_wbus_addr) & ",WDATA= 0x" & to_hstring(o_wbus_data);
The big problem is, Vivado STILL doesnt support these new functions in their simulator.
