VHDL-2008 target aggregate assignment BUG
I have found a bug concerning assignment to aggregates. The assignment fails when one of the target signals has a width of 0.
Here is an example I have been testing on:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity EXAMPLE is
generic(
    WIDTH : natural := 8
port(
    CLK   : in std_logic;
    IN_A  : in  std_logic_vector(WIDTH-1 downto 0);
    IN_B  : in  std_logic_vector(WIDTH-1 downto 0);
    OUT_A : out std_logic_vector(WIDTH+1-1 downto 0);
    OUT_B : out std_logic_vector(0-1 downto 0)
end entity;
architecture FULL of EXAMPLE is
    signal result : unsigned(WIDTH+1-1 downto 0);
begin
    my_process : process (CLK)
    begin
        if (rising_edge(CLK)) then
            result <= ("0" & unsigned(IN_A)) + ("0" & unsigned(IN_B));
            (OUT_A, OUT_B) <= std_logic_vector(result);
        end if;
    end process;
end architecture;
This code should correctly calculate the sum of IN_A and IN_B and propagate the result to OUT_A. However, in the aggregate assignment Vivado (2019.1.1) synthesis incorrectly evaluates the width of OUT_B as 2 and the result of is signal OUT_A is actually 'OUT_A <= "00" & result(WIDTH+1-1 downto 2)'.
This is the result of synthesis:
Best regards,
kenobi314159
Voyager
Voyager
As far as i know the definition of std_logic_vector is :
type std_logic_vector is array (natural range <> ) of std_logic;
And therefore OUT_B : out std_logic( -1 downto 0 ) is illegal.
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
Hi @kenobi314159
There seems to be an issue in the handling of null type ports when used in aggregate slices. Simulation mismatch can be seen in a simple assignment-
(OUT_A, OUT_B) <= ("1" & IN_A);
I will keep you posted on my findings further.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
@kenobi314159
I suspect its related to Vivado's bad handling of port ranges - see the following bug report
https://forums.xilinx.com/t5/Synthesis/BUG-VIVADO-2019-2-2008-Null-arrays-have-non-zero-length-through/td-p/1048292
@calibra
While std_logic_vector is ranged with a natural, the VHDL standard allowed any index if the range results a null range. So -ve values here are allowed. It means you can have a standard genericed port map and allow 0 length and not give an elaboration error.
generic (
  W : natural;
port ( ip : in std_logic_vector(W-1 downto 0);
Hi @kenobi314159
This is an issue with handling on null ranges and I have filed bug report for this. This issue will be fixed in future release.
-Shreyas
