VHDL Conversion help
I need to convert a Verilog statement into VHDL. I am not sure if I have done it in correct way. Here I am posting both for review. Please have a look at it and let me know if it correct or wrong. Thanks.
Verilog:
wire full = ((wr_ptr_gray_reg[ADDR_WIDTH] != rd_ptr_gray_sync2_reg[ADDR_WIDTH]) &&
             (wr_ptr_gray_reg[ADDR_WIDTH-1] != rd_ptr_gray_sync2_reg[ADDR_WIDTH-1]) &&
             (wr_ptr_gray_reg[ADDR_WIDTH-2:0] == rd_ptr_gray_sync2_reg[ADDR_WIDTH-2:0]));
VHDL:
  if ((wr_ptr_gray_reg(GC_ADDR_WIDTH) /= rd_ptr_gray_sync2_reg(GC_ADDR_WIDTH)) and
             (wr_ptr_gray_reg(GC_ADDR_WIDTH-1) /= rd_ptr_gray_sync2_reg(GC_ADDR_WIDTH-1)) and
             (wr_ptr_gray_reg(GC_ADDR_WIDTH-2 downto 0)= rd_ptr_gray_sync2_reg(GC_ADDR_WIDTH-2 downto 0))) then
			 full <= '1';
			 else
			 full <= '0';
			 end if;
Re: VHDL Conversion help
full <= '1' when  ((wr_ptr_gray_reg(GC_ADDR_WIDTH) /= rd_ptr_gray_sync2_reg(GC_ADDR_WIDTH)) and
             (wr_ptr_gray_reg(GC_ADDR_WIDTH-2 downto 0)= rd_ptr_gray_sync2_reg(GC_ADDR_WIDTH-2 downto 0))) else '0';
Maybe this should work.
--Sebastien
Verilog doesn't distinguish between boolean and logic types; VHDL does.  If you have declared full as a boolean signal, the code could look very similar to the Verilog original:
full <= ((wr_ptr_gray_reg(GC_ADDR_WIDTH) /= rd_ptr_gray_sync2_reg(GC_ADDR_WIDTH)) and
         (wr_ptr_gray_reg(GC_ADDR_WIDTH-2 downto 0)= rd_ptr_gray_sync2_reg(GC_ADDR_WIDTH-2 downto 0)));
If full is a variable (rather than a signal) the code would look the same but with <= replaced by :=
