Visitor car.oro
VHDL help with latch
Someone can help me to avoid this warning? The code is:
signal 'signal': STD_LOGIC := '0';
name_process: process (A, B)
begin
if ( A = '1' and B = '1' ) then
       signal <= not signal;
else
       signal <= signal;
end if;
end process;
in which 'A' and 'B' are input  STD_LOGIC and 'signal' is a signal STD_LOGIC.
the warning is "WARNING:Xst:737 - Found 1-bit latch for signal <signal>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems."
Re: VHDL help with latch
Hi @car.oro
this statement: signal <= not signal; is wrong in a asynchronous process.
If you want to keep this, you need to add a clock and make if a synchronous process.
--Sebastien
Visitor car.oro
I also tried it, but my signal have to change only when A and B are 1, not also when my clk is on rising edge
Well the flip flop created within the synchronous process is a memory of one bit to store the signal value.
If you can't use it, you need to accept the latch but it's not recommanded.
--Sebastien
Visitor car.oro
How can I use it? I have to avoid the latch
I'd code like this:
process(clk)
begin
   if rising_edge(clk) then
        end if;
    end if;
end process;
Be advised that signal will only be updated on rising edge of the clock.
--Sebastien
Scholar drjohnsmith
do you follow why your getting the latch ?
as a suggestion, can you use the two signals as enables, to a clocked process ?
Visitor car.oro
in this case, my signal changed every time that I'm on rising edge.. but I need that it changed only when A and B are 1 (so, for example, if I have A=1 and B=1 for more clocks, it have to change only the first time)
Visitor car.oro
yes I understand why I get the latch, but I don't understand how to resolve
No, your signal will only be inverted (toggle) whenever the A=1 & B =1 condition is true at each rising edge of the clock.
Otherwise, signal is memorized (it will stay still).
--Sebastien
Scholar drjohnsmith
What Im hearing is you want to detect when A and B go to '1' , and then toggle the output.
what happens is A goes to 1 ahead of B, do you want to toggle once when B get to '1' , or not toggle because both A and B did not go to 1 together.
Visitor car.oro
yes, but I need that if A and B are 1 for more clocks, the signal will be inverted only at the first rising edge, not for every rising edge.
For example, if in the test bench I had:
A<='1';
B<='0';
wait for 10 ns;
A<='1';
B<='1';
wait for 10 ns;
A<='1';
B<='1';
wait for 10 ns;
A<='0';
B<='1';
wait for 10 ns;
A<='1';
B<='1';
wait for 10 ns;
if my signal is 0 when A=1 & B=0, it became 1 when A=1 & B=1, but after 10ns, when I have again A=1 & B=1, it will still be 1. Then, A became 0 and my signal will still be 1. When I have again A=1 & B=1, now it will inverted to 0
I guess even your asynchronous process was not behaving like that.
--Sebastien
Visitor car.oro
my asynchronous process behaving like I told in my last reply because in the sensitivity list there are only A and B, so it toggle only when the input changed
It would not work the same way on the FPGA. signal is required in your sensitivity list. You should have also a warning related to this in synthesis.
You need to use a synchronous process and consider some kind of "lock" to prevent your signal from toggling at each clock cycle when your condition is met. the lock could be released when the condition is false.
--Sebastien
I have not simulated. but, it could be somthing like this.
process(clk, rstb)
begin
   if (rstb = '0') then
        signal <= '0';
        lock <= '0';
   elsif rising_edge(clk) then
        if ( A = '1' and B = '1'  and lock = '0') then
            lock <= '1';
        else
            lock <= '0';
        end if;
    end if;
end process;
--Sebastien
Visitor car.oro
rstb is a reset?
anyway, I already tried something like this, but it doesn't work. It changed two times and then it became stable, maybe because the lock signal changed after 1 time of clock and not immediatly, but if I use a variable it became 0 every time I begin the process.
Yes it's a reset.
I suggest you review your testbench or put it on the next post. Is your clock a 10ns period?
--Sebastien
Visitor car.oro
There are my stimulus ( the vector "concorrente" is "A" and "B"):
-- insert stimulus here
rst<='1';
wait for clk_period;
rst<='0';
concorrente <= "01";
concorrente <= "00";
concorrente <= "10";
concorrente <= "11";
wait;
end process;
If you're using my process, the reset is active low. So your stimuli are holding the flip flop in reset state.
Try this:
rst<='0';
rst<='1';
--Sebastien
Visitor car.oro
Yes I know that your reset is active when is low, infact when I used your code I write the inverted if condition. (if reset=1 then ). I'm sorry that I haven't specified before
Scholar drjohnsmith
WHere have you gotten to on this ?
I think what you need is a simple rising_edge detection on a&b? Like
signal a_and_b_dly: std_logic;
... process begin wait until rising_edge(clk); a_and_b_dly <= a and b; if a_and_b_dly = '0' and (a and b) = '1' then signal <= not signal; end if; end process;
As already told, the original sensitivity list is incomplete. If this would be complete, the simulator would tell you, that signal would never stabilize when a and b are '1'. This would lead to a combinational loop, and in hw maybe an oszillator.
Visitor car.oro
it have the same problem of before: if I have more than 2 A=1 and B=1 consecutive, my signal behaves like: 1->0->1->1->1->....->1 when I need something like this: 1->0->0->...->0 (in case of more A=1 and B=1 consecutive)
Scholar drjohnsmith
I for one could do with a diagram from you, showing the A and B inputs and what you want the outputs to do . In particular what do you want the output to do when A and B change together, and the case where A changes ahead of B ( or vice versa ) . Some idea as to the speed / frequency of A / B changing would be of use also.
Visitor car.oro
I want that at every A=1 and B=1 NOT consecutive, my signal changed. But, if A=1 and B=1 are consecutive for more clocks, my signal toggled only one time. My project is a buzzer and A and B are the players. If the players pushed the buzzers together, the turn becomes of one of the two. If later will be another pushed together, the turn becomes of the one that haven't speak at the first together's pushed.
Scholar drjohnsmith
A picture of the timing diagram would be a great way to illustrate this question.
There are two ways to approach this, asynchronous, or synchronous,
Your input signals are buttons , which are relatively slow compared to even the slowest clock.
   as such I'd be looking at a synchronous design.
This sounds like a fun high school project ?
Problems to solve.
a) the buttons are going to bounce, so first thing is to interface these and de bounce,  google de bounce.
    This will involve sampling the A and B inputs with the clock .
b)   Now you have clock synchronises signals, then you can use the synchronous process example.
I'd suggest turning the A and B onto one clock pulses,   then use a state machine type of approach , but there are many ways of cracking this nut.
Visitor car.oro
can you tell me some examples of codes? thanks
Scholar drjohnsmith
Visitor car.oro
I've looked, but I don't think it's what I need..
