MaximPiz
VIVADO 2020.1: Attribute ASYNC_REG set to "FALSE" prevents insertion of SRL16
The following code highlights the problem. Although the ASYNC_REG feature is set to "FALSE", no shift register is used and the code becomes huge.
library ieee;
use ieee.std_logic_1164.all;
entity test_ff is
generic (
   delay : positive := 512 );
port (
   clk : in std_logic;
   reset : in std_logic;
   x : in std_logic;
   y : out std_logic );
end test_ff;
architecture rtl of test_ff is
signal x_sr : std_logic_vector(delay-1 downto 0) := (others => '0');
attribute ASYNC_REG : string;
attribute ASYNC_REG of x_sr : signal is "FALSE";
begin
y <= x_sr(0);
process(clk)
begin
   if rising_edge(clk) then
      x_sr <= x & x_sr(delay-1 downto 1);
   end if;
end process;
end rtl;
If the attribute is left out completely, the synthesized code is only 5 slices versus over 100 slices. I wanted to use code like this to be able to infer a variable-length-flipflop with async set or unset. But because the attribute, by just be being there, prevents the insertion, I cannot use such code as shown below (using a generic to set async_reg). Looks like a bug in Vivado.
library ieee;
entity test_ff is
generic (
   delay : positive := 512;
   async_opt : string := "FALSE" );
port (
   clk : in std_logic;
   x : in std_logic;
end test_ff;
attribute ASYNC_REG of x_sr : signal is async_opt;
begin
y <= x_sr(0);
process(clk)
begin
   end if;
end process;
end rtl;
florentw
HI @MaximPiz
I have checked internally and indeed this seems to be an issue in vivado. It seems that was found internally so it was already reported.
However, it seems that it was too late to make it for 2020.2 and the fix will only make it for 2021.1.
Florent
MaximPiz
Hi @florentw
thanks for your message and how it will be resolved.
Best regards.
