matttay
Verilog confusion or synthesis bug?
Hi, still somewhat new at verilog. I've stripped down a problem I'm having to bare bones. This may or may not be the issue I am seeing on a larger piece of code, but I don't quite understand why there are buffers signals on the schematic (circled in yellow) pointing the wrong way. In the large piece of code I'm working on, when I route "din" wires external to view on a logic analyzer everything starts working. Here, it's not quite the same. But as a first step, can someone explain why the buffers look to be pointing the wrong way?
module Main(
    input Clk,
    input Select,
    output [1:0] Data
wire [1:0] din;
reg [1:0] Counter;
assign din = (Select) ? Counter : 2'h1;
assign Data = din;
always @(posedge Clk)
    Counter <= Counter + 1;
endmodule
austin
m,
The little red triangles are not buffers: they are splitting the bus into separate wires, or combining separate wires into a bus...
Austin Lesea
Principal Engineer
Xilinx San Jose
austin
m,
Austin Lesea
Principal Engineer
Xilinx San Jose
matttay
Understood, thanks!
emaits
so how can i know it is combining or spliting? is there any specific direction of that red triangle?
thanks~
eteam00
Professor
Professor
The schematic pasted in mattay's first post in this thread makes the answers quite clear.  Look at the signal names on either side of the red triangles.
-- Bob Elkind
SIGNATURE:
Summary:
