kenryan2
Verilog implicit nets
Is there a way to tell Vivado synthesis (2016.2) to refuse to accept an implicitly declared wire or reg?  I keep getting bit by a typo in a name happily synthesizing into a ground rather than getting flagged as an error.
tud_hartmann
Hi @kenryan2,
`default_nettype directive is what you are looking for. Simply write
`default_nettype none
at the beginning of your Verilog file, but don't forget to reset it at the end:
`default_nettype wire
Best Regards,
Stephan
tud_hartmann
Hi @kenryan2,
Best Regards,
Stephan
kenryan2
Ah, thank you!
