Observer sjjma
Vivado 14.2 No ram usage after successful synthesis
I used Vivado ip catalog to generate a simple dual port ram & instantiated it in my rtl.
Synthesis was successful & the LUT count looks right but the memory usage in the utilization report shows 0.
I'm doing the same thing as I did in ISE & ISE shows the ram. What's different about Vivado ?
Everything is regenerated in Vivado. Nothing from ISE.
Re: Vivado 14.2 No ram usage after successful synthesis
Are there any related critical warnings shown by the tool during synthesis? Can you attach both Vivado synthesis report and Utilization report ?
Ashish
Observer sjjma
The reports + original source verilog are attached.  The ram is just a simple dual port with registered inputs & outputs and always enabled.
Strange, won't let me add attachment. Complains about content not matching type.
Observer sjjma
module ram512x36_test ( wr, datain, clka, clkb, wradr, rdadr, dataout, datain2 );
input wr;
input [35:0] datain;
input [35:0] datain2;
input clka;
input clkb;
input [8:0] wradr;
input [8:0] rdadr ;
output [35:0] dataout ;
wire wr;
reg [35:0] datawr ;
wire [35:0] datain;
wire [35:0] datain2 ;
wire clka;
wire clkb;
wire [8:0] wradr;
wire [8:0] rdadr ;
wire [35:0] dataout ;
always @ (posedge clka )
datawr <= #1 datain + datain2 ;
ram512x36x rbits70( .wea( wr ), .dina( datawr ), .addra( wradr ) ,
.clka( clka ), .clkb( clkb ),
.addrb( rdadr ) , .doutb( dataout ) ) ;
endmodule
Here's the original source. Perhaps you can just run it.
Observer sjjma
Observer sjjma
It worked !!! **bleep**. This is really messed up.
As ooc is enabled for the ip, the top level synthesis report will not show the ip utilization.
Open synthesized design and run report_utilization command in tcl console to see the correct utilization.
Deepika.
Deepika.
