Anonymous
Not applicable
Vivado 2014.2: [Synth 8-561] range expression could not be resolved to a constant
Hi guys,
I want to assign following variable:
v_bust_len_original(11-v_shift_burst_size downto 0) := v_data_read(11 downto v_shift_burst_size);
Unfortunately, this result in the error message:  [Synth 8-561] range expression could not be resolved to a constant
It seems that Vivado doesn't fully support this dynamic assignments.
However, how can I rewrite this clause to make it synthesizable? (v_shift_burst_size is an integer ranged from 0 to 7).
Best regards
Robert
Re: Vivado 2014.2: [Synth 8-561] range expression could not be resolved to a constant
Robert,
You need to write a case or an if-elsif chain against all possible permutations of v_shift_burst_size.
If my memory is correct, you only need to have a constant expression on the left side of the assignment, the right side may be left with a signal.
i.e.
case (v_shift_burst_size) is
  when others => v_bust_len_original(11-0 downto 0) := v_data_read(11 downto v_shift_burst_size);
  when 1 => v_bust_len_original(11-1 downto 0) := v_data_read(11 downto v_shift_burst_size);
  when 2 => v_bust_len_original(11-2 downto 0) := v_data_read(11 downto v_shift_burst_size);
  when 3 => v_bust_len_original(11-3 downto 0) := v_data_read(11 downto v_shift_burst_size);
  when 4 => v_bust_len_original(11-4 downto 0) := v_data_read(11 downto v_shift_burst_size);
  when 5 => v_bust_len_original(11-5 downto 0) := v_data_read(11 downto v_shift_burst_size);
  when 6 => v_bust_len_original(11-6 downto 0) := v_data_read(11 downto v_shift_burst_size);
  when 7 => v_bust_len_original(11-7 downto 0) := v_data_read(11 downto v_shift_burst_size);
end case;
Hope this helps.
Vlad
Vladislav Muravin
Historian
Historian
@Anonymous wrote:
Hi guys,
It's certainly legal VHDL but it can't be synthesized. The indices need to be constant at compile time.
You should be able to sort of unroll the whole thing and use a loop to do the assignment to the various bits based on the v_shift_burst_size variable.
Robert,
i.e.
end case;
Hope this helps.
Vlad
Vladislav Muravin
stumble upon the smiliar issue with Vivado 2015.3 and 2016.1
here is my 'problematic' (from a Vivado of course) code snippet :
architecture RTL of DLY_VAR is
  signal reg     : std_logic_vector(2**K -1 downto 0);
  signal DLY_int : integer range 1 to 2**K-1;
begin  --  of arch
  main : process(NRST, CLK)
  begin
    if NRST = '1' then
      B       <= '0';
      reg     <= (others => '0');
      DLY_int <= 1;
    elsif rising_edge(CLK) then
      if EN = '1' then
        -- latching the queuing delay value
        DLY_int <= 2**to_integer(unsigned(DLY));
        if DLY_int = 1 then
          B <= A;
        else
          reg(0)                  <= A;  -- input to queue
          reg(DLY_int-1 downto 1) <= reg(DLY_int-2 downto 0);  --shifting
          B                       <= reg(DLY_int -1);          --output
        end if;
      end if;
    end if;
  end process main;
end architecture RTL;
This is a shame! since it gets fully synthetized with ISE 14.7 and Quartus 15 (Altera).
@Xilinx: Why such a regression?! WtF, are you sleeping or what?!^^
This is *not* the way for people switching to Vivado, better off sticking with ISE!
Florian
Using Vivado 2015.4 and having the same problem! Created a new thread.
:-o
Disappointed to hear this. But for 7 series devices, I must use Viv 2015.4!
FPGA enthusiast!
All PMs will be ignored
Vivado 2017.2
The same issue here!
Xilinx guys work very hard :D :D
@florianfrank14: I so fully agree, you should not adopt code, valid code, to a tool !
@ all Vivado creators: This is absolute bull$hit to say the very least !!!
We had a company internal package for re-usable design units. "Code" that has been used for years and years and years in various environments and for various FPGAs (Xilinx Virtex-2, Virtex-6, different CPLDs and FPGAs from Lattice and Actel) and hence with various tools (ISE since version 10, Various DesignExpert, various ispLever versions, Libero...) and also different simulators (Modelsim, various Active-HDL versions) ... it has all worked out perfectly fine
... until Vivado came along !!!
So the necessity to now duplicate the code and re-write it (because it is still used by old tools when re-compiling older projects and risking changing behavior there is not an option).
IP-centric workflow with design re-use is how it is euphemistically called in the Vivado marketing ... but duplication is what is necessary instead
IMHO a new tool version can incorporate many many things (from new GUI over new capabilities, performance improvements up to licensing price increments) but it should not render previously done and proven-good work useless !
Bjoern
Can confirm this is still broken in 2017.4.
I use the word "broken", even though this post is marked as solved specifically because of @bsmann's point regarding code reuse and the inability to use shared proven HDL in Vivado projects.
This needs to be a regression that is fixed going forward.
Thanks for checking in Vivado 2017.4 !
This syntax was working fine on a ISE 14.4 project I have, that I cannot migrate to Vivado because of this. How come it did work a decade ago but it doesn't work on vivado?
Hi @jsammy
yes it is still broken. So, as we were forced to move from ISE to Vivado using Artix (and to be fair, Vivado also has many plus sides as well as negative ones) we needed to duplicate sources and re-worked them.
In all our cases this could be done by using shift (SLL, SRL) functions with dynamic parameters instead of vectors with dynamic ranges.
So going from old version:
-- Helper function " U = Fi_Unsigned (V)" converts a std_logic_vector V to an unsigned integer U.
-- all inputs (p.ve_ and p.e_ ) are values set by software during run time (std_logic_vector or std_logic format)
si_Cmd_Length <= (Fi_Unsigned (p.ve_Cmd_Length) + 1) when (p.e_Cmd_LenZero = '0') else 0;
if (bLSB_nMSBfirst) then
    sv_SPI_Write <= p.v_WrData;
else
    sv_SPI_Write(sv_SPI_Write ' left downto sv_SPI_Write ' left - si_Cmd_Length + 1) <= p.v_WrData (si_Cmd_Length - 1 downto 0);
end if;
to new version
else
sv_SPI_Write <= p.v_WrData SLL (32 - (si_Cmd_Length + Fi_Unsigned (p.ve_DataPulses) + 1));
end if;
Even if I have to admit that that the new version is quite a bit more readable (and should be technically equivalent and hence likely should work also in the old designs), I still think that the decision to update/change legit and proven code should be at the users discretion.
But maybe the above snippets might help you guys to adopt your existing RTL (if you decide to do so) or might even inspire the Vivado creators on how to silently translate this old RTL into something functional equivalent that Vivado Synthesis will compile ;-).
Björn
Kind of wish VHDL had the "+:" and "-:" slicing operator like verilog...
If your design is already mixed Verilog and VHDL you can just use  Verilog Instead of VHDL for one of the modules?
    assign vector2 = vector1[pos:+8];
