Vivado 2015.4 Abnormal program termination during DRC
I would like to use Vivado 2015.4 Tcl Shell for a out-of-context-mode estimation of resource usage for a DFT core. The DFT core is from the famous spiral.net DFT core generator and wrapped with hand-coded VHDL. I use a tcl script for estimating the resource usage via non-project-mode synthesis and implementation.
After the logic optimization step, I would like to generate a DRC report. During this, Vivado encounters a "Abnormal program termination" and stops running. I attached all relevant design files, the compilation tcl script, its outputs, and the error dump in a zip file.
What can I change to not crash Vivado?
Cheers
Re: Vivado 2015.4 Abnormal program termination during DRC
@the_box
I looked into the shared design and script at my end. With 2016.2 design is passing, can you migrate your design to 2016.2?
If not, try to disable multi-threading in your script and let us know if that helps.
Anusheel
Helpful answer -> Give Kudos
@the_box
Anusheel
@anusheel
I'm using Vivado 2016.2 now and the compilation is successful. Thank you!
Cheers
