Voyager
Voyager
Vivado 2015.4 Macro Defined in Verilog Header File Incurs Critical Warning
Same design source never had any warning messages in Vivado 2015.2.
Critical WARNING:
[HDL 9-870] Macro <SOME_MACRO> is not defined. [file_name.v:80]
[HDL 9-281] Cannot open include file "header.v". [file_name.v: 48]
I can see the header.v is under Design Source in folder "Verilog Header". Interesting thing is at the original state of project upgrading from 2015.2, the icon of the verilog header file is blue. Tried delete it once during troubleshooting, the file stays and icon changes to greenish.
Regardless these warnings, design synthesize without issue.
Any comments?
Hi @legendbb,
Can you see verilog header under non-module files?
It should be having green colour icon.
Also verify the property of that file.
Attaching snapshot for your refernce.
Arpan
Arpan
@legendbb,
It would be helpful if you can share the test case to replicate the issue.
Also try to set Global_Include property on Verilog header file and see if you are still seeing the same warning:
--Syed
Google your question before posting.
If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)
@legendbb,
Check this AR#51164 on defining verilog macro in Vivado:
http://www.xilinx.com/support/answers/51164.html
--Syed
Voyager
Voyager
Thanks for attention. I do have the same thing in your illustration.
The macro I used is actually for implementation.
An example snippet:
`define UNPACK_ARRAY(LOOP_IDX, PK_WIDTH, PK_LEN, PK_SRC, PK_DEST) \
  generate  \
    for (LOOP_IDX=0; LOOP_IDX<(PK_LEN); LOOP_IDX=LOOP_IDX+1) begin \
        assign PK_DEST[LOOP_IDX][((PK_WIDTH)-1):0] = PK_SRC[((PK_WIDTH)*LOOP_IDX+(PK_WIDTH-1)):((PK_WIDTH)*LOOP_IDX)]; \
    end \
  endgenerate
