Scholar drjohnsmith
Vivado 2018.2 , multi tasking NOT
have a design, with many IP blocks in it
in the GUI,
  I modify one of the IP's , ( a clock wizard in this case , need to change a clock frequency )
     then say generate,
          away it goes, I click on background,
great
While thats running, I want to modify another , a different IP block ( this one a fifo )
     I double click the fifo I have, but nothing happens,
The little circles go around and around, and I get another coffee and wait whilst vivado sorts itself out...
When its finished generating the clock, it alows me ( very nice of it ) to double click on the fifo , to modify it.
Scholar jmcclusk
Re: Vivado 2018.2 , multi tasking NOT
If you want true parallel synthesis,  you'll need to move to a scripted flow, possibly using parallel make to generate multiple DCP files that are combined before running place and route.    It's a complicated problem, and there are serious issues with passing generic parameters from the top of the hierarchy down to the bottom.
Scholar drjohnsmith
I dont want parallel makes,
I just dont want one tool to be blocked because another is running,
   why cant' I re configure an IP block whilst another is being synthesis ed ?
sounds like bad programming to me, not a fundamental .
