Vivado 2018.2 synthesis failed without error
Recently I have installed Vivado 2018.2 (Webpack) in my workstation, when I was trying to synthesis a very simple RTL.
It shows status: synth_design ERROR, but no errors are generated in the messages window.
However in the RTL analysis (inside Flow Navigator) I am able to see the schematic properly.
So what could be possible source of error as the code is written fine as given below (in Italic).
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity tri is
Port ( a : in STD_LOGIC_VECTOR (2 downto 0);
b : in STD_LOGIC_VECTOR (2 downto 0);
c : out STD_LOGIC_VECTOR (2 downto 0));
end tri;
architecture Behavioral of tri is
begin
c <= a and b;
end Behavioral;
Thanks & regards
Madhur
Scholar drjohnsmith
Re: Vivado 2018.2 synthesis failed without error
There will be a message , probably in the TCL window , but basicaly you have bad VHDL, you need a process in there, else its and empty entity.
Try
begin
mb : process( a,b )
begin
c <= a and b;
end process mb;
end Behavioral;
Hello drjohnsmith
I think that's not issue with the code, what I have written is the concurrent statement.
And as already mentioned in my original post, I am already getting the schematic being generated. (attached for reference) from the same code.
As far as Messages are concerned, snapshot of TCL console and messages are attached below.
regards
Madhur
Scholar drjohnsmith
I only have ISE to hand today,
   but this passes just fine
library IEEE;
entity tt_t is
end tt_t;
architecture Behavioral of tt_t is
begin
    c <= a and b;
end Behavioral;
Hi @mjuneja ,
This is a machine specific issue.
Run your testcase in another directory and make sure it has all the permission to write and read and modify.
If it does not help, then run "report_environment -file <filepath>/env.txt" in tcl console and provide env.txt to evaluate. To check which file path run pwd.
hemangd
Hi @hemangd
Please check the attached env.txt file and suggest the possible solution..
@mjuneja
Can you attach the synthesis log file here? That may help us to understand better what went wrong at your end.
Anusheel
Hi @mjuneja ,
Turn off your anti virus temporarily and run synthesis.
Also your APPDATA path contains whitespace - APPDATA=C:\Users\Madhur Juneja\AppData\Roaming
Remove that white space and restart your machine and then run synthesis.
hemangd
Hi @hemangd
After disabling the antivirus, still the synthesis failed with no errors and warnings..as well as the progress halts at 0%.
However this time I have opened Vivado by running vivado.bat in location C:\Xilinxv\Vivado\2018.2\bin.
After synthesis failed, in the command window I am getting <project_path>synth_1\rundef.js<25,1> WshShell.Exec: Access is denied.
@anusheel Certain attachments from synth_1 folder is attached for your reference.
Madhur
Hi @mjuneja ,
Move your project or create a new project on directory where you have full access and write/modify permissions. Otherwise you will endup with the similar issue.
hemangd
@mjuneja
synth_design was not even called when the crash occurred. Looks like permission issue as already mentioned.
Also, try to reinstall Vivado if you have all the permissions and still tool/machine does not allow synthesis to complete.
Anusheel
@anusheel
Actually as far as permission is concerned I am already logged in as administrator.
Initially I was working on Vivado 2018.2 where I was facing this isssue, but after uninstalling this version and installing the latest version Vivado 2018.3 situation has changed.
Now synthesis is not stopping at all (for the same code already shared in the original post) and it's been more than 12 hours since I started the synthesis run.
No message or warning is being shown in the TCL window and progress stuck at 0%.
However in the command window I am seeing the same error earlier reported.
"<project_path>\<project_name>.runs\synth_1\rundef.js<25,1> WshShell.Exec: Access is denied."
Somehow I am able to correlate this error with
https://forums.xilinx.com/t5/Synthesis/SYNTHESis-DOEsN-T-START/td-p/537407
But I am not able to crack this issue yet.
Script files rundef.js and ISEWrap.js are attached for your reference, and both these files are same in project folder as well as in Vivado script folder.
And my antivirus has not quarantined any of these script file.
Thanks & regards
Madhur
