Vivado 2018.3 Support For System Verilog Wildcard Equality Operators
UG901 (v2018.3) indicates in Table 8-1 on p.276 that wildcard equality operators are supported.  Where are such operators explicitly listed/referenced in the document?  Note that they appear to not be present under Operators on p.266.
What text character sequences are used to specify such operators (e.g., =?= and ==? (as seen from an Internet search) are clearly incorrect)?
Where can the System Verilog documentation/reference used in formulating Vivado support for System Verilog be found?
Hi @chsdkj,
I think the one which one which are mentioned in System Verilog LRM are the supported one's.
Raj.
Hi @chsdkj,
Raj.
