ymherklotz
Vivado 2019.1 Bit selection synthesis mismatch
There seems to be a mismatch between the synthesised net list and the initial design with the following Verilog code. This happens with Vivado 2019.1 on my personal arch linux machine and Vivado 2018.2 on CentoOS 6. I have attached all the necessary files to run it and hopefully reproduce it, together with a testbench that dumps a vcd file.
I have reduced the Verilog as much as possible, and changing anything else makes Vivado synthesise correctly.
module top (y, clk, w0);
   output [1:0] y;
   input clk;
   input [1:0] w0;
   reg [2:0] r1 = 3'b0;
   reg [1:0] r0 = 2'b0;
   assign y = r1;
   always
     @(posedge clk) begin
        r0 <= 1'b1;
        if (r0) r1 <= r0 ? w0[0:0] : 1'b0;
        else r1 <= 3'b1;
     end
endmodule
For an input of w2 = 2b'10 for two clock cycles, the final output should be 2'd0, because the if statement is entered on the second clk cycle and the lsb of w0 is assigned to r1, which is 1'b0.
However, with Vivado the output seems to be 2'10 instead, which seems like Vivado does not truncate the value of the input to the lsb in w0[0:0].
Expected output after 2 clock cycles with 2'b10 as input: 2'b00
Actual output: 2'b10
Tags (3)
pulim
Hi @ymherklotz
I am able to reproduce this issue at my end and filed CR to fix this issue in future releases.
As w1[1] is unused, declaring w1 as single bit can be used as workaround to move forward with design.
Hope this helps.
Manusha
pulim
Hi @ymherklotz
Hope this helps.
Manusha
ymherklotz
Great thank you! That works.
markcurry
Does this bug affect any priori Vivado versions.  i.e. 2018.*?
This looks to me to be a rather critical bug.  @ymherklotz  - did you try your test on any other Vivado version?
@pulim are there any other details available on what triggers this bug?  Only in Vivado 2019?  Or others too?
Mark
ymherklotz
@markcurry, I have managed to reproduce this with 2016.2, 2017.4, 2018.2 and 2019.1, so it seems to be present in all those versions. Maybe @pulim can give more details though.
All the best,
Yann
pulim
Hi @markcurry
Yes, This issue is there from atleast 2017.1.
I can give you more details once I get update on this CR.
