Vivado 2019.1 Elaboration : ERROR: Cannot resolve hierarchical name for the item 'MODULE_NAME_INSTANCE'
Is hierarchical signal access not supported for synthesis?
I am trying to re-organize my code by placing the ILA cores in the top level. Hierarchical references to lower levels of the design are made and assigned to ILA inputs. I get an error for each reference.
Below is an example of what I'm talking about. The error would occur at the assignment during RTL elaboration.
module top(...);
module_name module_name_instance(
byte data;
assign data = module_name_instance.internal_data;
endmodule
If this isn't supported is there any plan to add support?
Re: Vivado 2019.1 Elaboration : ERROR: Cannot resolve hierarchical name for the item 'MODULE_NAME_INSTANCE'
Hierarchical naming is not supported and currently there is no plan to support it.
Any reason why? It's a valid language construct after all.
Page 238 AND 284 of UG901 lists "hierarchical names" as "Supported."
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug901-vivado-synthesis.pdf
It seems that it has been this way for a few versions now.
Hi @dpikul ,
Hierarchical referencing is supported. Could you post snippet of code ?  Also do you have module for "module_name_instance" compiled/added ?
For example, please check snapshot.
Ajay
Hi, @dpikul ,
I refer to the roadmap page out-of-date, and in current Vivado synthesis tool Hierachical naming is supported.
Sorry for the confusing.
All the hierachical name used in the source code should be defined by the user.
Ajay,
The snippet I posted is very similar to my code just with names obfuscated.
The entire design currently goes through implementation and runs on hardware, the build will not go through elaboration though if I use hierarchical referencing.
Hi @dpikul ,
It could help if you can share design to get better idea.
Ajay
"module_name_instance" cannot be the current module itself.
For example
module aaa (...);
wire data;
assign data = bbb.internal_data;
bbb  my_inst (...);
endmodule
Just have a try.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
