Vivado 2019.1 Signed with shift in condition synthesis mistmatch
The following code seems to give a mismatch after synthesis. I am using Vivado 2019.1 on my personal Arch Linux machineg and Vivado 2018.2 on CentOS 6.
module top  (y, w0);
   output [1:0] y;
   input        w0;
   assign y = $signed(2'h1 < 2'h2) >> w0 ? 1'b1 : 1'b0;
endmodule
When the module is given w0 = 0, the output should be 1, because $signed(1 < 2) >> 0 = 1. However, synthesising the module gives the following net list in Verilog:
// Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
// Tool Version: Vivado v.2019.1 (lin64) Build 2552052 Fri May 24 14:47:09 MDT 2019
// Date        : Tue Jun 11 15:26:35 2019
// Host        : yann-arch running 64-bit unknown
// Command     : write_verilog -force syn_vivado.v
// Design      : top_vivado
// Purpose     : This is a Verilog netlist of the current design or from a specific cell of the design. The output is an
//               IEEE 1364-2001 compliant Verilog HDL file that contains netlist information obtained from the input
//               design files.
// Device      : xc7k70tfbg676-3
`timescale 1 ps / 1 ps
(* STRUCTURAL_NETLIST = "yes" *)
module top_vivado
   (y,
    w0);
  output [1:0]y;
  input w0;
  wire \<const0> ;
  wire [1:0]y;
  GND GND
       (.G(\<const0> ));
  OBUF \y_OBUF[0]_inst
       (.I(\<const0> ),
        .O(y[0]));
  OBUF \y_OBUF[1]_inst
       (.I(\<const0> ),
        .O(y[1]));
endmodule
Which assigns the output y to a constant 0.
I have attached a tcl file with the Verilog file so this can hopefully be reproduced.
Tags (3)
Hi @ymherklotz
Thanks for reporting this issue.
I am able to reproduce this issue at my end in 2019.1. 2016.x version doesn't have this issue. From 2017.1 this issue is seen.
I have filed a CR to fix this issue in future releases of vivado.
Manusha
Hi @ymherklotz
This looks to be issue with this usage $signed(2'h1 < 2'h2).  By changing this to (2'h1 < 2'h2) creates correct netlist.
You can use this as workaround to move forward with your design.
Manusha
