taichi730
Vivado 2019.1 [Synth 8-448] named port connection error on parameterized interface port
I got "[Synth 8-448] named port connection" error when I tried to synthesize following code.
Code:
interface test_if #(type PAYLOAD = logic);
  typedef PAYLOAD __payload;
  PAYLOAD payload;
  modport in(input payload);
  modport out(output payload);
endinterface
module sub_0 (
  test_if.in  in,
  test_if.out out
  assign  out.payload = in.payload;
endmodule
module sub_1 (
  test_if.in  in,
  test_if.out out
  typedef in.__payload  __payload;
  test_if #(__payload)  sub_if_in();
  test_if #(__payload)  sub_if_out();
  assign  sub_if_in.payload = in.payload;
  assign  out.payload       = sub_if_out.payload;
  sub_0 u_sub_0 (.in(sub_if_in), .out(sub_if_out));
endmodule
module top (
  input   logic [1:0] i_foo,
  output  logic [1:0] o_foo,
  input   logic [2:0] i_bar,
  output  logic [2:0] o_bar
  typedef struct packed {
    logic [1:0] foo;
  } foo_type;
    logic [2:0] bar;
  } bar_type;
  test_if #(foo_type) foo_in();
  test_if #(foo_type) foo_out();
  test_if #(bar_type) bar_in();
  test_if #(bar_type) bar_out();
  assign  foo_in.payload.foo  = i_foo;
  assign  o_foo               = foo_out.payload.foo;
  sub_1 u_foo (.in(foo_in), .out(foo_out));
  assign  bar_in.payload.bar  = i_bar;
  assign  o_bar               = bar_out.payload.bar;
  sub_1 u_bar (.in(bar_in), .out(bar_out));
endmodule
Error Message:
[Synth 8-448] named port connection 'in\.payload[bar]' does not exist for instance 'u_sub_0' of module 'sub_0' ["/home/ishitani/workspace/test/test_9515/test.sv":27]
[Synth 8-448] named port connection 'out\.payload[bar]' does not exist for instance 'u_sub_0' of module 'sub_0' ["/home/ishitani/workspace/test/test_9515/test.sv":27]
[Synth 8-6156] failed synthesizing module 'sub_1__parameterized0' ["/home/ishitani/workspace/test/test_9515/test.sv":15]
[Synth 8-6156] failed synthesizing module 'top' ["/home/ishitani/workspace/test/test_9515/test.sv":30]
[Common 17-69] Command failed: Vivado Synthesis failed
Is there any problem on above code?
I confirmed that other tool (SNPS VCS) can elaborate without error.
Taichi Ishitani
pulim
Hi @taichi730
Thanks for pointing to this issue in other thread.
I am able to reproduce this issue in 2019.1 at my end.
I tested and confirmed that this issue is already fixed in next release of vivado.
Hope you can use the workaround that you have till next release is available for customers.
Manusha
xilinxacct
Professor
Professor
@taichi730
Here are a couple solutions that had the same error. Maybe they will give you some insight.
https://forums.xilinx.com/t5/Synthesis/quot-Synth-8-448-named-port-connection-clk-does-not-exist-quot/m-p/941955#M30074
https://forums.xilinx.com/t5/Synthesis/Understanding-Solving-Synth-8-4480-quot-The-timing-quot/m-p/693260#M17918
Hope that Helps
If so, Please mark as solution accepted. Kudos also welcomed. :-)
taichi730
Hi @xilinxacct ,
Thank you for your advice. However I thik these could not be solutions because:
  • There are no dupulicated modules.
  • There are no warning and error except for [Synth 8-448].
  • There are no timing issue.
Port informatin used for top.u_foo.u_sub_0 is propergaed via top.u_foo.sub_if_in interface and port information used for top.u_bar.u_sub_0 is propergated via top.u_bar.sub_if_in interface. Therse port informatin should be different.
However it's seemed that wrong port information is propergated to top.u_bar.u_sub_0 and this wrong information is for top.u_foo.u_sub_0.
I think this issue is caued by Vivado's bug.
Taichi Ishitani
markcurry
I believe your failure has to do with the following line in sub_1:
As far as I'm aware Vivado doesn't support pulling out a parameter (or typedef)  from within an interface outside to the enclosing module.  There's other threads in these forums talking about this restriction - those threads explicitly talk about parameters, as I recall, not typedefs per your example, but I believe the restriction is the same.
It's a shame really, because what you're doing really enables some compact, reusable, high-level object-oriented design.
Search around the threads a little - if you can't find the threads let me know, I can dig and send references.
Mark
taichi730
Hi @markcurry ,
Thank you for your replay!
Unlike the case of parameter, this type of typedef is legal (see IEEE 1800-2017 "6.18 User-defined types") and also is supported by Vivado.
In fact, top module below can be syntheiszed without error.
module top (
  input   logic [1:0] i_foo_0,
  output  logic [1:0] o_foo_0,
  input   logic [1:0] i_foo_1,
  output  logic [1:0] o_foo_1
    logic [1:0] foo;
  } foo_type;
  test_if #(foo_type) foo_in_0();
  test_if #(foo_type) foo_out_0();
  test_if #(foo_type) foo_in_1();
  test_if #(foo_type) foo_out_1();
  assign  foo_in_0.payload.foo  = i_foo_0;
  assign  o_foo_0               = foo_out_0.payload.foo;
  sub_1 u_foo_0 (.in(foo_in_0), .out(foo_out_0));
  assign  foo_in_1.payload.foo  = i_foo_1;
  assign  o_foo_1               = foo_out_1.payload.foo;
  sub_1 u_foo_1 (.in(foo_in_1), .out(foo_out_1));
endmodule
Taichi Ishitani
markcurry
Taichi,
Typedefs, and parameterized types are supported by Vivado, and have been for some time.
What is NOT supported by Vivado, and what's missing from your second example here, is pulling the value (or type) from within an interface outside to the module's scope.
I.e. In this second example, "foo_type" is explicitly defined in the scope of module "top", and hence is allowed by Vivado.
However, In your original:
Within the scope of the module "sub_1", type "__payload" is NOT explictly defined.  You're attempting to pull the definition from the within the interface that is passed to that module.  While this is legal verilog, it has not been properly supported in Vivado.  I believe this is the root cause of your problem.
Mark
taichi730
Hi @markcurry ,
Thanks for you replay.
this second example
This is a part of exmaple and whole exmaple is below.
  PAYLOAD payload;
endinterface
module sub_0 (
  test_if.in  in,
  test_if.out out
endmodule
module sub_1 (
  test_if.in  in,
  test_if.out out
endmodule
module top (
    logic [1:0] foo;
  } foo_type;
endmodule
Vivado can synthesis above code without error.
Vivado would report the same error if Vivado doens not support "typedef in.__payload __payload". Therefore, I think error for 1st example is due t Vivado's bug.
Regads,
Taichi Ishitani
pulim
Hi @taichi730
Manusha
zhua
I see a similar issue with Vivado 2020.1. In which version of Vivado is it fixed? I there a workaround instead of waiting for a new release? Thanks.
taichi730
I think adding 'type' parameter to the sub_1 module like this is easiest workaround.
module sub_1 #(
  parameter type PAYLOAD = logic
  test_if.in  in,
  test_if.out out
  test_if #(PAYLOAD)  sub_if_in();
  test_if #(PAYLOAD)  sub_if_out();
endmodule
module top (
    logic [1:0] foo;
  } foo_type;
    logic [2:0] bar;
  } bar_type;
  sub_1 #(foo_type) u_foo (.in(foo_in), .out(foo_out));
  sub_1 #(bar_type) u_bar (.in(bar_in), .out(bar_out));
endmodule
