Vivado 2020.1 TCL The object 'run' does not have a property 'STEPS.SYNTH_DESIGN.ARGS.FANOUT_LIMIT'.
I have one piece of TCL code working for Vivado 2018.3, i am trying to move to Vivado 2020.1 but i cant set the fanout limit as before using Vivado synthesis 2020.
create_run synth_1 -flow {Vivado Synthesis 2020}
set_property STEPS.SYNTH_DESIGN.ARGS.FANOUT_LIMIT 100 [get_runs synth_1]
When using the last instruction :
ERROR: [Common 17-54] The object 'run' does not have a property 'STEPS.SYNTH_DESIGN.ARGS.FANOUT_LIMIT'.
Hi @ellorens ,
There are multiple options not all are listed below:
opt_design -hier_fanout_limit
physopt_design -fanout_opt (default)
Along with this their are various directives you can choose , please refer UG904 : Vivado Design Suite User Guide: Implementation
Ajay
Hi @ellorens ,
Synth_design option "fanout_limit" is deprecated. You can use options in placer, physical synthesis for fanout handling.
Ajay
Could you please provide an example? It would be very helpful to have a proper update of that tcl code so we can close the topic.
Thank you in advance
Hi @ellorens ,
Ajay
