Vivado [Synth 8-27] access type not supported
Here is a simple function that converts bool to string.  It synthesizes fine in ISE 14.5, but chokes in Vivado 2013.1 (using Vivado synthesis defaults):
function sel(condition: boolean; a,b: string) return string is
variable x : line;
begin
  if condition then
    write(x,a);
  else
    write(x,b);
  end if;
  return x.all;
end function;
The synthesis error is on the return x.all line.  The error specifically is:
ERROR: [Synth 8-27] access type not supported.
My googling resulted in no hits on this error.  I am probably doing something foolish, but I sure can't figure it out.
  Any thoughts?
Understood.
The "access" keyword has special meaning in VHDL. It allows access to dynamically allocated data (like strings of undefined length). It works like a pointer in C. There isn't any real hardware meaning that I'm aware of.
I've never tried to synthesize these types in XST. My guess is that XST may have a built-in workaround to ignore those types and only throw warnings if related logic isn not pruned.
Is this VHDL? Is that write() function from the textio package?
The write() function is generally meant for debugging in a simulator. It is not synthesizable. You need to instruct your synthesis tool to ignore your sel function, or the parts in it that use the write() function.
I always forget the mundane details...
Yes it is VHDL.
Yes it uses the textio library, which is previously declared with the other libraries:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
library UNISIM;
use UNISIM.VComponents.all;
library std;
use std.textio.all;
Yes I agree it is not synthesizable.  It is used for conditional simulator behavior.
That said, the ISE 14.5 synthesizer does not choke on it.  Vivado 2013.1 does choke on it.  I am trying to determine what option I am missing in Vivado that seems to be turned on by default in ISE.  Or, perhaps the Vivado synthesis tool cannot ignore this construct.
Try wrapping the statements in
--synthesis translate_off
--synthesis translate_on
Thank you.
I was hoping to get more details on the Synth 8-27 error and exactly what syntax is inappropriate.
Understood.
You can solve your issue with the following code snippet. This can be used in simulation and synthesis.
    -- if-then-else function
    function ite(condition: boolean; a,b: string) return string is
    begin
      if condition then
        return a;
      else
        return b;
      end if;
    end function;
