Anonymous
Not applicable
Vivado. Synthesis. ROM + DSP, registers absorbing.
Hi! I have next statements in my project:
if (rising_edge(CLK)) then
reg0 <= ROM(address);
reg1 <= reg0;
reg2 <= reg1;
mult_result <= reg2 * other_value;
end if;
I want to implement it this way: reg0, reg1 are absorbed to BRAM and reg2, mult_result are absorbed to DSP48E1.
But Vivado's synthesizer absorbs reg1, reg2 to DSP48E1 and reg0 - to BRAM, so after implementation it fails to meet timing.
What can I do to force absorbing by my way?
The VIVADO realizes that it can absorb 3 registers as AREG/BREG=1, MREG=1and PREG =2 and the BRAM readout is unregistered.
Possible solutions:
1. Add another pipeline in between and make sure it is not absorbing it as AREG=2/BREG=2, if it does, add yet another pipeline.
2. Instantiate BRAM/DSP manually
Vlad
Vladislav Muravin
Anonymous
Not applicable
Thanks, but I've found more elegant solution:
reg1 <= reg0;
reg2 <= reg;
end if;
reg <= reg1; -- with attribute "dont_touch" on "reg".
your solution works great. Thanks a lot.
Sebastian
