Vivado Synthesis error
Hi all,
I am facing issue while doing synthesis as like below image. If i will run continuously may be sometimes i am not getting errors with same design only. Where was the problem i was unable to understand. Please give me solution and do needful.
Thank you
amaccre
Hi harinatha.reddy@eldaas.com
How are you launching Vivado, are you doing so via the Windows Icons or using the command line.
It looks like the working directory for your project has been set to the route of your C: drive and you cannot write to there.
In the tcl console if you type pwd, what is being returned? If it is C:\ then this is your problem.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
anusheel
Can you please let us know which OS and Vivado version is used? Also, please try to run any of the Vivado Example Designs and let us know if those runs are failing as well.
Anusheel
