Vivado Synthesis "Requires" Connection To Verilog Module Output Ports!
When instantiating in Verilog a RAMB36E2 primitive, which has a total of 54 input and output ports, but leaving ten unneeded outputs unconnected, Vivado 2018.3 Synthesis issues the warning "...instance "foo' of module 'RAMB36E2' requires 54 connections, but only 44 given...".  Note the use of "requires", which is incorrect.
It would seem that this misleading warning message would be better reworded as "...instance "foo' of module 'RAMB36E2' has 54 connections declared, but only 44 given...", or even better: "...instance "foo' of module 'RAMB36E2' has 40 input and 14 output connections declared, but only 4 output connections given...".
Re: Vivado Synthesis "Requires" Connection To Verilog Module Output Ports!
Hi @chsdkj,
Enhancement Request has been filed for this warning messag. Developers team will look into and may make necessary changes as per the requirement for upcoming Vivado versions.
hemangd
Hi @chsdkj,
Can you provide a testcase show i can regenerate this warning at my end and file an enhancement request with the development?
If yes, i will share the ezmove ftp link.
hemangd
@hemangd,
Yes, I can.
Hi @chsdkj,
Ezmove ftp test package sent on your attached email id.
hemangd
Hi @chsdkj,
hemangd
